Command Line Start for Hideaway
watsonm
Postby watsonm Fri Aug 03, 2018 3:44 am
IS there a command line way of starting Hideaway so that I can put it into the start up folder?
Obviously need some method of defining the options but that could be what was last setup using the GUI.
Thanks...
Re: Command Line Start for Hideaway
Postby nick.bolton Fri Aug 03, 2018 8:51 am
The shortcut links to C:\Users\{your username}\AppData\Local\HideAway\HideAway.exe
But it's probably easier to find Hideaway in the start menu, right click and select 'open file location', then copy that to your start folder, or make another shortcut and place that in the startup folder.
We'll add in an option to start with Windows in the near future.
Postby nick.bolton Fri Aug 03, 2018 9:08 am
Actually, this might be easier to copy/paste
%LOCALAPPDATA%\HideAway then create shortcut of HideAway.exe
watsonm
Postby watsonm Fri Aug 03, 2018 8:51 pm
Nick,
Thanks...
I understand putting the shortcut in will fire up Hideaway but can command line options be added so it automatically starts a redirect with particular options and minimsed.
Postby nick.bolton Fri Aug 03, 2018 9:14 pm
Ah I see. We discussed that today, it's not implemented yet, but we'll add it in.
watsonm
Postby watsonm Sat Aug 04, 2018 8:45 pm
Thanks...
Who is online
Users browsing this forum: No registered users and 2 guests
