Shut down HideAway GUI version.
Download this http://cdn.firetrust.com/downloads/hide ... t-test.exe
Highlight this file in your downloads folder. Click the address bar in the top of File Explorer and type CMD, then hit Enter. The command line will appear for that directory (nice trick aye).
In the command line window, type
Code: Select all
hideaway-print-test.exe 2 1
Now try and print/scan something. Press CTRL+C to stop the redirection.
Then send us the log.log file from Start>>Run>>
Code: Select all
%appdata%
