After an auto-update to version 4.1.4 an old problem got back. After the update HideAway V 4.1.4 starts automatically. Initially, the checking updates windows is shown. After that, the Starting window, and then the process shuts down.
Is there a link to the latest beta version of HideAway so I can install it manually?
link to latest beta version
- Teljeur
Re: link to latest beta version
Thanks,
I uninstalled HideAway 4.1.4, rebooted and deleted all folders related to HideAway. Rebooted, run AVG PC Tuneup and rebooted again. Installed HideAway 4.1.4
This worked before but not this time. I noticed a different error message in the log.log file, see attachments
- SquirrelSetup.log
- (2.1 KiB) Downloaded 495 times
- log.log
- (923 Bytes) Downloaded 476 times
- nick.bolton
- The Big Cheese
Can I get you to please try this.
Perhaps send us a screenshot when it crashes or copy/paste the output.
Make sure HideAway is shut down. This is a command line version again.
Download here:
http://cdn.firetrust.com/downloads/hide ... f-test.exe
Then find the file in Explorer (probably in Downloads), and in the top title bar in Explorer, type cmd and press enter. That will bring up a black command line screen.
Type
hideaway-wpf-test.exe 2 1
Then press enter.
When it crashes, can you please send me the screenshot or copy/paste the output.
Thanks!
Download here:
Type
Then press enter.
Thanks!
- Teljeur
Well, that seems to work. My ip is redirected to ;
My IP Address Is:
IPv6: 2001:19f0:5800:8b4a:5400:ff:fe12:7901
IPv4: Not detected
ISP: Choopa, LLC
Country: United States
The output of the cmd;
Packet Init
Start Packet Thread
Start Packet Thread
Press enter key to stop...
Ping: 610
My IP Address Is:
IPv4: Not detected
ISP: Choopa, LLC
Packet Init
Start Packet Thread
Start Packet Thread
Ping: 610
- nick.bolton
- The Big Cheese
Thanks, is that command line version still running now?
That ping value seems high, are you on Satellite internet?
- Teljeur
nope, I don't have cable or anything like that. I living in a place that only got a 4G internet connection. And I killed the command line version because it was indeed slow.
- nick.bolton
- The Big Cheese
Thanks for the info, there seems to be a pattern here - it seems to be affecting people on slower, higher latency connections.
- nick.bolton
- The Big Cheese
Can you please try this version
It has more logging around the Registry. What antivirus program are you using? It seems like something is preventing HideAway from running other processes.
- Teljeur
Tried HideAway 4.1.6, no luck, after the HideAwayDriverSetup.exe it shuts down.
I am using Webroot SecureAnywhere
- nick.bolton
- The Big Cheese
Could you please post the logs again. Can you also check in SecureAnywhere that HideAway is not being blocked?
- Teljeur
HideAway is not blocked in SecureAnywhere. I tried HideAway with all options disabled in SecureAnywhere, and I added the file HideAway.exe to the allow list in SecureAnywhere. Makes no change.
- SquirrelSetup.log
- (2.93 KiB) Downloaded 504 times
- log.log
- (2.4 KiB) Downloaded 486 times
- nick.bolton
- The Big Cheese
Thanks for this
What other security software do you have installed on your PC? HideAway.exe tries to launch/spawn other executables, eg: reg.exe to check the registry and see if the driver is installed and it is being blocked by a 3rd party application on your PC. It's also blocking Update.exe and HideAwayDriverSetup.exe
- nick.bolton
- The Big Cheese
Hi, we found a bug in a 3rd party program we're using which would have made the first install not working properly
And see if it fixes the issue.
- Teljeur
Same result but this time a different error message in the log.log
- DxDiag.txt
- (83.2 KiB) Downloaded 475 times
- SquirrelSetup.log
- (2.1 KiB) Downloaded 447 times
- log.log
- (1.31 KiB) Downloaded 454 times
