BBC says not in UK and whatismyip say:
Your Public IPv4 is: 95.179.199.228
Your IPv6 is: Not Detected
ISP: Choopa LLC
Any ideas please
If you have HA set to iPlayer only, then yes this would be expected as it won't be redirecting the traffic for either the GRC or IPINFO domains. If you are seeing the behaviour when redirecting the whole machine, then something isn't right.watsonm wrote: ↑Tue Aug 13, 2019 8:39 pmNick,
I am in the UK and usually have the redirection set to all computer , UK.
As a test I set it to BBC Iplayer and using https://www.grc.com/shieldsup and https://ipinfo.io/ I got the same ip address as not using Hideaway at all.
Is this normal since I am in the UK. I would have thought it would still "hide" my IP. Obviously not a major issue for me but wanted to point it out.
This is using 4.2.1
Regards Mike
