Different background colours on Main Hideaway Screen
- LuckyPhill
Hi guys, how difficult is it to have a different background colour when HideAway is On or Off, e.g. a shade of light red for when one first opens the program & a light shade of green when it's actually connected? I run HideAway from my taskbar (bottom of screen) but can't tell if I'm connected or not without actually bringing the program up onto my screen! I can't distinguish the word "Connected" when viewed via the task bar!
- nick.bolton
- The Big Cheese
Re: Different background colours on Main Hideaway Screen
We just did it, and are testing it Will send the update soon
- nick.bolton
- The Big Cheese
Restart HideAway and you'll see it shows when connected in the Taskbar and System Tray
- LuckyPhill
Thanks guys - excellent outcome, the green dot which now appears (only) when connected is even a simpler & more effective way than my original suggestion - keep up the good work.
- poundgirl
Thank you for the green dot ... that makes things so much easier!
Lord, help me to be the kind of person my dog thinks I am.
And if there are no dogs in Heaven, then when I die I want to go where they went!
- LuckyPhill
