I just installed the trial on my computer, and I typed in "what's my IP address into my search bar, with it both running and not running. The IP addresses were the same. I hit the refresh/reload button on my Firefox, but that did not seem to resolve the issue. Am I missing something? Are there other tests I can do?
Alan
How to tell if HideAway is working
- alanstancliff
Re: How to tell if HideAway is working
After starting HideAway, try restarting the browser and see if that picks it up.alanstancliff wrote: ↑Thu Aug 22, 2019 9:38 pmI just installed the trial on my computer, and I typed in "what's my IP address into my search bar, with it both running and not running. The IP addresses were the same. I hit the refresh/reload button on my Firefox, but that did not seem to resolve the issue. Am I missing something? Are there other tests I can do?
Alan
- alanstancliff
Thanks, RD.
I shut down the browser and waited 10 minutes, and now it seems to be working fine. I purchased a license after that.
____________
Regards,
Alan Stancliff
Regards,
Alan Stancliff
Thanks for your support.
It should hopefully just need a restart, rather than waiting that long. Out of curiosity, which browser are you using ?
- nick.bolton
- The Big Cheese
Thanks. Sometimes Google Chrome will hold on to the existing connection for up to 30 seconds. We do try and clear the cache when HideAway starts a redirect.
- alanstancliff
- nick.bolton
- The Big Cheese
Can you go to Start, type Run, and then in the box that appears, type %appdata%
This will bring up a window. Go to the HideAway folder, and in there please send me the log.log file.
Thanks!
Thanks!
