I am having a problem with this latest upgrade.
No matter what I select in Redirect (all Computer or Firefox) and whatever location and then start Hideaway
https://www.grc.com/shieldsup and https://ipinfo.io/ both display my normal non hidden IP address.
Hideaway Status panel says connected , location points correctly to selected location and IP address displays
somethibng different to my real IP.
Have uninstalled and re installed with same problem. Have refreshed cache on browser.
[2019-08-23 19:31:49.312] [info] Startup: --squirrel-install C:\Users\watsonm\AppData\Local\HideAway\app-4.0.0 C:\Users\watsonm\AppData\Local\HideAway C:\Users\watsonm\AppData\Local\HideAway\app.ico
[2019-08-23 19:40:41.530] [info] Checking for update
[2019-08-23 19:40:42.441] [info] Update available
[2019-08-23 19:40:57.702] [info] Startup: --squirrel-updated C:\Users\watsonm\AppData\Local\HideAway\app-4.2.5 C:\Users\watsonm\AppData\Local\HideAway
[2019-08-23 19:41:04.181] [info] Relaunching to install update...
[2019-08-23 19:41:08.895] [info] Checking for update
[2019-08-23 19:41:09.597] [info] Update not available
[2019-08-23 19:41:09.753] [warn] Registry exception:
Error: Command failed: C:\WINDOWS\System32\reg.exe QUERY HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HideAwayDriver /v DisplayVersion /reg:32
ERROR: The system was unable to find the specified registry key or value.
at w (C:\Users\xxxxxx\AppData\Local\HideAway\app-4.2.5\resources\app\main.electron.js:1:7436)
at C:\Users\xxxxxx\AppData\Local\HideAway\app-4.2.5\resources\app\main.electron.js:1:8473
at processTicksAndRejections (internal/process/task_queues.js:89:5)
[2019-08-23 19:41:09.755] [info] Installing HideAway Driver
[2019-08-23 19:41:12.727] [info] Initialising HideAway engine
[2019-08-23 19:43:20.174] [info] Checking for update
[2019-08-23 19:43:21.105] [info] Update not available
[2019-08-23 19:43:24.020] [info] Initialising HideAway engine
Hideaway 4.2.5 not working
- nick.bolton
- The Big Cheese
Re: Hideaway 4.2.5 not working
Do you have another VPN installed and running on startup? The logs look fine.
Can you open a new private window in Firefox after redirecting HdieAway and see if that works?
- watsonm
I had Nordvpn running before but disabled it in startup and have rebooted several times .
Also disabled the TAP-NordVPN adapter as well. (didn't have to do this before!)
Opening another window didn't help.
- nick.bolton
- The Big Cheese
Thanks. Let me come back to you after talking to the developers. It's odd because in this latest update we only added a notification icon to show when it was connected.
One thing you could try, uninstall HideAway, restart your computer, then install HideAway.
- watsonm
Did this twice , same problem.
Had disabled autostart of NordVPN (using CCleaner startup option) but not uninstalled it.
- nick.bolton
- The Big Cheese
What version of Windows are you using, plus 32/64 bit?
We'll post a debug build for you to try soon to get to the bottom of this.
- nick.bolton
- The Big Cheese
Could you please try this
Shut down HideAway (system tray icon, right click and select Quit).
download this
http://cdn.firetrust.com/downloads/hide ... y-test.exe
Then in the Explorer download folder, click the top of the address bar and type cmd and click enter.
That will bring up the command line window
type hideaway-test.exe 2 1 and click enter
Can you please screenshot or copy/paste the output.
download this
- nick.bolton
- The Big Cheese
Could you also run this command to make sure the driver is installed and running.
sc query hideaway
sc query hideaway
- watsonm
Windows 10 64 bit auto update.
Disabled NordVPN in startup.
Disabled their ethernet adapter (TAP-NordVPN Windows Adapter V9)
reboot
sc query hideaway gave no output after following was run.
PS C:\Users\watsonm\Downloads> .\hideaway-test.exe 2 1
Packet Init
Start Packet Thread
Start Packet Thread
Press enter key to stop...
Ping: 261
UDP Ignore: 192.168.1.255
DNS Redirect: 192.168.1.1
UDP Redirect: 46.243.26.34
UDP Redirect: 109.74.206.120
UDP Redirect: 188.114.116.1
UDP Redirect: 217.114.59.66
UDP Redirect: 5.79.108.34
reboot
Packet Init
Start Packet Thread
Start Packet Thread
Ping: 261
- watsonm
Rebooted after above and then started normal Hideaway.
Redirected all computer to UK
Ran sc query hideaway
and also got no output
- nick.bolton
- The Big Cheese
Can I get you to uninstall HideAway, then restart your PC and install HideAway again.
run sc query hideaway.
It should say
SERVICE_NAME: hideaway
TYPE : 1 KERNEL_DRIVER
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
WIN32_EXIT_CODE : 0 (0x0)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
I wonder if your registry cleaner is removing some entries?
It should say
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
- nick.bolton
- The Big Cheese
Are you able to test this?
It's a bit more technical, it involves removing the current driver and replacing it with a previous driver.
Don't start the HideAway program with the GUI, or this won't work.
Download these two files
http://cdn.firetrust.com/downloads/hide ... tupOld.exe
http://cdn.firetrust.com/downloads/hide ... -debug.exe
Run cmd.exe as Administrator
Type cd c:\Users\{your username}\Downloads
This will change the directory you’re in. My username is Nick, yours will be something else
Now type
HideAwayDriverSetupOld.exe -u
Restart Computer
Run cmd.exe as Administrator (like above)
sc query hideaway
Should say something like
HideAwayDriverSetupOld.exe -i
type
sc query hideaway
hideaway-test-debug.exe 2 1
Go to https://ipinfo.io see if it shows the correct IP address in Australia.
Now type
Restart Computer
sc query hideaway
type[SC] EnumQueryServicesStatus:OpenService FAILED 1060:
The specified service does not exist as an installed service.
type
sc query hideaway
typeSERVICE_NAME: hideaway
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
- nick.bolton
- The Big Cheese
Could you try this version http://cdn.firetrust.com/downloads/hide ... -setup.exe and see if it fixes any issues. Probably best to uninstall,. restart PC and then install it.
- watsonm
Because of our time/distance apart I have only just got this list of things to do so here goes:
1)
Disabled NordVPN startup (using CCleaner)
Disabled CCleaner smart cleaning in startup
Disabled NORDVPN.service in services.msc
Disabled the NordVPN TAP-NordVPN ethernet shim.
Unistalled HA
Reboot
Installed HA
result of SC command
C:\WINDOWS\system32>sc query hideaway
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
2)
Unisnatll HA
Reboot
Install HideAwayDriverSetupOld.exe -u
reboot
sc query hideaway
as expected...
ran HideAwayDriverSetupOld.exe -i
sc query hideaway
Output
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
ran hideaway-test-debug.exe 2 1
and https://ipinfo.io showed australian site ip address.
Will now uninstall and run HideAway-4.2.6-setup
1)
Unistalled HA
Reboot
Installed HA
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
2)
Unisnatll HA
Reboot
reboot
sc query hideaway
as expected...
sc query hideaway
Output
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
- watsonm
4.2.6 also failed as before.
Did following test:
Stopped the redirect and exited HA
Went into task manager and killed all instances of Hideway. (there were three )
went into my downloads and ran
HideAwayDriverSetupOld.exe -u (presume -u mean uninstall driver)
sc query hideaway showed service not installed as expected.
rebooted
ran HideAwayDriverSetupOld.exe -i (presume -i means install driver)
rebooted and ran HA 4.2.6 gui seemed to work. Could toggle hideaway on and off (although seemd to have to kill firefox and restart it
to get correct answer, maybe I am impatient and should have waited a bit longer as mentioned in one of the other posts.)
Will just do retest to confirm.......
So has old driver actually been put back into 4.2.6?
Did following test:
rebooted
