Run %LOCALAPPDATA%
Go back a directory
Right click "Local"
Click "Properties"
Click "Security"
and take some screenshots of the permissions etc
Also, go to Advanced and take screenshots too
Installation failure.
- RGC
Re: Installation failure.
I already tried the "run as administrator" option to no avail.
- Security.JPG (74.94 KiB) Viewed 4640 times
- Advanced.JPG (91.08 KiB) Viewed 4640 times
- nick.bolton
- The Big Cheese
I have to say we're stumped on this one. All the permissions are ok, but it's saying otherwise. We'd really have to be able to replicate the issue on our side to fix it, but we don't know how to get to that point sorry.
- sparkyspark
Having the same issue, upgraded two identical laptops from windows 7 to windows 10 and HideAway would not work on either laptop after upgrade.
Uninstalled HideAway and deleted all folders in Users folder etc and reinstalled the latest version on both machines, one installed okay and the other gave the same error messages as this thread and failed to install.
I will send you the squirrel logs and another log for the successful install and the squirrel log for the failed install and send them to forum@firetrust.com
I'm running KIS Total Security and have tried with KIS disabled but still no joy, as I said the laptops are identical so it is most likely something to do with the windows 10 upgrade where all files and programmes were kept during the upgrade, did not do a clean install on either.
Log Files Sent to forum@firetrust.com
Thankyou
Thankyou
- nick.bolton
- The Big Cheese
What happens if you try to run the installer as Administrator and set Compatibility to Windows 7 or 8? (try both)
We'd just tried to run the installer as Administrator in the past. Right click on the installer and select Properties, then Compatibility tab and select Windows 7.
- sparkyspark
Running them both on Widows 7 and 8 compatibility mode and with the installer as Administrator still doesn't work,nick.bolton wrote: ↑Wed Nov 27, 2019 4:17 pmWhat happens if you try to run the installer as Administrator and set Compatibility to Windows 7 or 8? (try both)
- sparkyspark
Just noticed there was an update to version 4.4.0 on the machine that was working okay, so tried it on the problem laptop that would not run the installer and hey presto it's now allowed the install and HideAway 4.4.0 is working as it should.
Don't know what'schanged to allow it to install this time but thanks for the update guys, solved it for me at least
- nick.bolton
- The Big Cheese
Oh that's interesting. We changed the digital certificate for the installer to one from a company which has been around for longer (Digicert) than the one we were using. Odd if it's just that, but glad that it's working.
