If I select iPlayer I get the message: "This site can’t be reached www.bbc.co.uk unexpectedly closed the connection."
If I select All Computer & London it all redirects ok.
iPlayer FYI
- nick.bolton
- The Big Cheese
Re: iPlayer FYI
Can you please try again, sometimes we'll unexpectedly get assigned a residential IP address which is not working properly (gets turned off for example). But most of the time it should work.
- Paraf
Re: iPlayer FYI
I tried a few times but no luck. Same message.
If I set HA to iplayer & go to https://www.bbc.co.uk/iplayer/live/bbcnews Then I get the not in UK message - thought that would fall under the iplayer settings?
It all works fine with all computer redirect but would be nice to separate.
Will try again tomorrow
- nick.bolton
- The Big Cheese
Re: iPlayer FYI
Hi
Sorry about this, we're not quite sure what's going on at the moment. Hopefully we'll have it resolved shortly.
- Paraf
Re: iPlayer FYI
Same issue today.
No other report on forum so could be something on my end but it works with 'all computer'
Will keep watching
Same issue today.
Will keep watching
- nick.bolton
- The Big Cheese
Re: iPlayer FYI
There's definitely something going on. I can get it working, but it seemed intermittent. Have another user with this issue also.
- nick.bolton
- The Big Cheese
- Paraf
Re: iPlayer FYI
No luck - Not recognizing the redirect - "This content is not available in your location"
All BBC site & cookies info cleared - don't know if some other id is hiding somewhere!
Tried Chrome & Firefox.
- nick.bolton
- The Big Cheese
Re: iPlayer FYI
Thanks for letting me know. Can you try the instructions in this link and let me know if it helps?
https://kb.wisc.edu/31480
- Paraf
- nick.bolton
- The Big Cheese
- Paraf
Re: iPlayer FYI
still complaining about location with iplayer selected.
With all computer it works in incognito but not in std even with all BBC cookies cleared.
Hope this helps
Hope this helps
- nick.bolton
- The Big Cheese
Re: iPlayer FYI
Ok, it's pretty frustrating - we've got a few users with this issue, and it's working for others without any problem. Still looking...
What antivirus are you using?
- g6radio
Re: iPlayer FYI
Nick
Problem here getting "watch bbc iplayer" to work, same problem as reported above.
No antivirus
version 4.91
firefox and chrome
Nick... please advise the correct procedure to get bbc iplayer selection to work assuming :
Just booted pc
no antivirus
HA not yet open
No other programs open..
We need the exact steps needed to get "watch bbc iplayer" to work.
During this lot of tests i had no problems with selecting london and all computer or chrome and london...
2 different PCs same problem as mentioned by others
No antivirus
version 4.91
firefox and chrome
Just booted pc
no antivirus
HA not yet open
