I Love this Software..But:-
Whenever I allow my Windows 10 Laptop to entre Sleep Mode with Hideaway up and connected I have no Internet Connection when Windows restarts.
The only way I have found to get things working again is to reboot my router.
Is there a known problem in this area?
Windows 10 Sleep Mode Problem
- nick.bolton
- The Big Cheese
Re: Windows 10 Sleep Mode Problem
That shouldn't be happening at all, one of the features of HideAway is it's ability to roam, which means that it will stay connected when you start Windows, switch Wifi to ethernet to 4G etc.
Could you try the tips at https://www.windowscentral.com/how-rega ... windows-10
In particular: How to reset network stack using Command Prompt
Let us know how you get on.
- Jancux
Thank you Nick,
I can confirm that this problem does not occur on my other Windows 10 Laptop!
I have executed the reset of the network stack as outline by your link
But:
It still happens every time!
Despite the Internet Access icon indicating no Internet Connection everything works fine, TeamViewer is connected and internet browsing works fine.
Disconnecting HideAway results in an automatic correction to the Internet Access icon returning to normal.
Best Regards
Jerry
But:
Best Regards
Jerry
- nick.bolton
- The Big Cheese
Hi Jerry
So, everything works all ok - it's just the internet connection icon?
Any of these help? https://www.google.com/search?q=network ... sconnected
They're mostly Windows 7, but it might help in your case.
