BBC iPlayer and ITV is blocked When I choose Watch BBC iPlayer and Watch ITV, also by choose Redirect All Computer.
Regards
Frank.
- g6radio
Re: BBC iPlayer and ITV is blocked
Frank
Are you using kaspersky internet security by any chance?
If not what anti virus program are you using?
cheers
cheers
- oz9fb
Hi there, no I am using F-Secure but both are working now.
Thanks.
Frank.
Thanks.
Frank.
- poundgirl
Hi Frank, is All Computer working with BBC for you ?
I haven't been able to connect with it to any UK channels for over a week and have been hoping for an update on this other topic
viewtopic.php?f=59&t=32150
Lord, help me to be the kind of person my dog thinks I am.
And if there are no dogs in Heaven, then when I die I want to go where they went!
- nick.bolton
- The Big Cheese
Got a bit further with it, and gave the provider more info so they better fix it asap
- oz9fb
No, it only work by - Watch BBC iPlayer
Regards
Frank.
Hi'poundgirl wrote: ↑Mon Aug 10, 2020 6:20 pmHi Frank, is All Computer working with BBC for you ?
Regards
Frank.
- nick.bolton
- The Big Cheese
Give it a try again now. I can get it working, but through using a private browsing session initially as it seems that iPlayer remembers you not being able to connect for a while and will keep showing you that message regardless.
- nick.bolton
- The Big Cheese
- poundgirl
Every morning I test All Computer with both incognito and the usual way hoping something has changed but I've just tried again and still no joy ..
- nick.bolton
- The Big Cheese
Can you please give this a try
Just close down HideAway, then download and install this version. It's working fine here
- poundgirl
I've done that now but still can't watch with All Computer
- nick.bolton
- The Big Cheese
You'll need to use 'Watch BBC iPlayer' option. It's only by chance that it's worked in the past by connecting directly to UK/London in the past, as sometimes that IP address would get unblocked.
- poundgirl
Do you mean just until it's fixed? I've always used All Computer since installing Hideaway and not the BBC option as the iPlayer download doesn't work otherwise.
- nick.bolton
- The Big Cheese
We are redirecting the iPlayer downloads too now, so they should work.
When we get the custom rules in there (just working on the user interface now) you'll be able to have ALL COMPUTER and bbc iplayer running together.
But, now our upstream residential IP address provider is having issues again! So can't get to iPlayer right now...
- poundgirl
This is what I get now
This site can’t be reached www.bbc.co.uk unexpectedly closed the connection.
I've tried reloading the page for about 10 minutes but it hasn't changed
Edit: ITV redirect is doing the same now but I'll keep trying with both
When you use the BBC redirect the ITV webpage loads and vice versa
