HideAway Won't Run After Update
Col
Mon Aug 17, 2020 9:43 pm
Both Windows 10 and HideAway updated (v4.11.3) and now HideAway won't run.
It loads, but just sits with the "CHECKING FOR LICENSE" icon greyed out.
I can select Show License Key, which displays my current active key.
I have uninstalled and reinstalled HideAway with the same issue.
Thanks.
Re: HideAway Won't Run After Update
Mon Aug 17, 2020 10:33 pm
Can you re-activate your key. Meaning, re-enter your key and press the Activate button. Did that help?
Otherwise, can you shut down HideAway, Right click in system tray and select Quit
Then download and install this version.
Col
Tue Aug 18, 2020 12:05 am
Re-activating the key did the trick.
Thanks Nick.
