vienna not working?
mabgate
vienna not working?
Sun Apr 11, 2021 6:55 pm
austria, vienna dosn't working for me. the connect is green but the latency shows -1ms and no data is transmitted. Is that only for me or can someone confirm it?
Re: vienna not working?
Sun Apr 11, 2021 8:02 pm
Sorry, should be working again now
mabgate
Mon Apr 12, 2021 12:21 am
top! THX for that quick response. :bow
mabgate
Sun Apr 18, 2021 12:11 am
Hello at all,
vienna is hanging again. please repair it for us. THX again
Sun Apr 18, 2021 1:39 am
It seems ok to me, I'm connecting ok and the speeds are fine.Can you check again?
koehtobi90
Mon Apr 19, 2021 3:27 am
During Formula 1 races the speed is quite low.
Mon Apr 19, 2021 6:51 am
Ok, is this for the Vienna server? I get about +100mb/s from New Zealand for it which should be more than enough for streaming video
Can you let me know the formula1 website you're watching from?
Also, do you use MalwareBytes? There's a feature with it called 'Web Protection' and it slows your internet connection quite considerably. So you could disable it if it's being used.
koehtobi90
Mon Apr 19, 2021 7:48 pm
It's only during the races. There are no streaminproblems during the pre- and post-race-shows.
https://tvthek.orf.at/live
https://www.servustv.com/sport/
I don't use MalwareBytes.
Mon Apr 19, 2021 7:57 pm
How fast is your internet speed without HideAway? Also have you tried a different web browser?
What about if it's set to a lower resolution for the video when you're watching the race? I know when there's a lot of fast movement, it takes a lot more processing power compared to more slower pictures.
koehtobi90
Mon Apr 19, 2021 11:20 pm
My internetspeed is about 50 Mbit/s and i tried diffenrent browsers.
It's possible to watch the races with lower resolution but than i can use a free vpn aswell und save my money.
Tue Apr 20, 2021 8:53 am
Do the free VPNs have the same problems?
Is it 4k or 1080?
If you go to speedtest.net with HideAway active, do you get close to 50mb/s?
koehtobi90
Wed Apr 21, 2021 4:55 am
I haven't used one until now.
720p
Wed Apr 21, 2021 7:54 am
OK, that should be fine to watch 720p.
It would be interesting to try on a different computer, or friends computer and see if the same issue is there. It might come down to performance of the computer itself.
koehtobi90
Mon May 03, 2021 1:12 am
Now the download speed of the vpn connection is about 2.7 MBit/s. Much too slow for streaming the race.
mabgate
Mon May 03, 2021 2:10 am
Hello,
unfortunately dropped out again... pls fix it.
thx!
