403 error at Digikey.com
dsicon
Sun May 30, 2021 9:35 am
I have latest version 4.17.0
I am now able to use Los Angeles server but I can't connect to digikey.com, I get a 403 error
I can connect and log into other similar sites
If I use Jacksonville server instead of Los Angles I can connect to digikey.com, what can I do?
Re: 403 error at Digikey.com
Sun May 30, 2021 11:20 am
Thanks, it looks like Digikey have blocked the IP address so I've asked to unblock it (it might have been used inappropriately in the past). Dallas works with digikey
dsicon
Sun May 30, 2021 12:33 pm
Thanks,
now Mailwasher throws an error for GMAIL (only GMAIL) when most but not all Hideaway servers are used, I already have the google reduced security thing set
any ideas
Mon May 31, 2021 6:30 am
It's probably because it's using new IP addresses if in HideAway you haven't checked the box 'Don't redirect my email'
Probably the best thing to do with Gmail is to create an app password. https://www.firetrust.com/products/mail ... quirements as Gmail seems to ignore the reduced security thing sometimes.
dsicon
Wed Jun 02, 2021 6:31 am
Now Mouser.com does not work using Los Angeles, things seem to be getting worse.
I think I will need to find a different VPN, this just isn't working for me, and I bought two licenses
Wed Jun 02, 2021 8:42 am
Sorry, I think we've found the solution. We're just testing it now. Will let you know when it's done.
Wed Jun 02, 2021 3:24 pm
Can you please shut down HideAway (right click and select Close or Quit)
Download this version
and install it. That should fix your issues for now.
