SOME torrents are slow
BugBlatBeast
Sat Feb 26, 2022 11:26 am
I am using qbittorrent v4.4.1 and Hideaway v4.18.3. Some torrents I try to downlaod are really slow when connected yet others seem to be fine. Doesn't matter if I connect with "Redirect torrent application" or "Redirect computer". I was previously using a service that has SOCKS5 proxy and this wasn't a problem. I have disabled that proxy. Are there any specific connection settings that need to be set? Any advice?
Re: SOME torrents are slow
Sun Feb 27, 2022 7:19 pm
Hi, yes we've noticed this too. Currently looking in to it...
OGVasyaPupkin
Sun Mar 13, 2022 10:55 am
I'd like to clarify the issue:
UDP trackers all work fine, but HTTP trackers start showing "The requested address is not valid in its context" error as soon as I enable the HideAway and the error goes away as soon as I disable it.
As a workaround I can do an announce with HideAway disabled and continue download after enabling it, peer connections work fine
Mon Mar 14, 2022 5:16 pm
Can you please try again now and see if it's working for you.
BugBlatBeast
Thu Mar 17, 2022 8:04 am
Hey Nick, I was able to test today and it does seem to be better. Thanks for the help :)
OssianF
Sun Oct 22, 2023 10:38 pm
I´m using qBittorrent v4.5.5 and HideAway 4.20.1 and no torrent downloading starts. If I disable HA and try the same torrent it works. Same thing on two different PC´s. Both with W11, latest updates.
Mon Oct 23, 2023 9:18 am
Hi, yes we're currently trying to fix this. WIll update when it's done
ftzippo76755
Thu Feb 15, 2024 4:21 pm
Hello! I always appreciate your positivity in overcoming problems. Glad that the error was fixed quickly
Asherslobe
Sat Mar 02, 2024 10:53 pm
Is there any additional information or updates regarding the issue with qBittorrent and HideAway mentioned on October 22, 2023?
