first of all i want to tell that is a very interesting VPN.
PRO
- very fast in connection
-very fast in navigation (you forget to be under a vpn while in net)
and very important for me
- you can set to not redirect your email client (is the only VPN I found to have this feature)
the only fatal CON
-fail the ipleack test.
you can check yourself to this link test
https://vpntesting.com/
your really IP will be detected despite you are under this VPN.
This is not accettable by a VPN. I use it just to surf protect by the wall of a VPN.
I made also another test. I used a Ukranian IP just to connect to a site that accept only ukranian people.
It tell me that I am not from Ukraine.
I read in the FAQ that for resolve ip leack you suggest to change the setting of the browser, but this is not the solution.
A customer does not want be bother with core settings in various browser if pay for a VPN.
I made the same test with same browser with other 3 different VPN and the only IP was the one of the VPN and not mine.
Dont get me wrong, my criticism is for push your team to work for make this wonderful VPN to be perfect.
My future plan will be to buy lifetime license, but not before this security hole will be solved.
Alex
ip leack failed
- nick.bolton
- The Big Cheese
Re: ip leack failed
Hi Alex
Thanks for your feedback/comments. They are appreciated.
The reason you get an IP Leak if you don't redirect your whole computer is because Windows has other processes running like svchost.exe which are often DLLs etc and these can be accessing the internet also. So if you only redirect your web browser then there's all these other processes running which can leak your IP address.
We're working on releasing filters soon which will let you redirect different apps to different locations simultaneously.
As for the Ukrainian server, IP addresses don't have location associated with them. So while the Ukraine server is in Ukraine, we can't rely on any other services knowing this. All those IP location websites are just guessing.
NIck
NIck
- security_blog
Re: ip leack failed
Thank nick for the replay.
When I made the test of course I used the rule to redirect whole computer, so the test should not leack my IP.
I read about the new interesting feature of custom filter, but this feature is for advanced user that like to fine tune the VPN.
99% of user want click 'n go, so the option "redirect whole computer" shouldn't protect from ip leack?
Alex
Alex
- khanyash
Re: ip leack failed
Try this-
1. Disable WebRTC in the browser.
2. Disable SecureDNS in the browser.
3. Connect HideAway and then start the browser.
- security_blog
Re: ip leack failed
Thanks, I did such modifications in chrome and now the ipleack tes not show my ip.
I just wonder why with other vpn providers not need to make some modifications to the standard browser configuration.
Maybe they just add this settings in their client?
- nick.bolton
- The Big Cheese
Re: ip leack failed
I did have a user say there's a WebRTC leak, so we're investigating that. Normally it would work without any browser modifications.
- security_blog
Re: ip leack failed
Nice. Hope you can find the solution to use standard configuration browser as normally should be.
For now I installed a chrome extension called "WebRTC Leack prevent" and disabled the SecureDNS option.
I will stay tuned for the new client feature.
Good job
Alex
Good job
Alex
- khanyash
Re: ip leack failed
You have to disable SecureDNS in browsers with other VPNs too, otherwise DNS tests will fail, i.e., show your DNS.security_blog wrote: ↑Mon Apr 18, 2022 1:03 amThanks, I did such modifications in chrome and now the ipleack tes not show my ip.
- security_blog
Today I tested again this VPN and look like some changes are done because, with standar browser, failes only one test of WebRTC leack, yesterday failed more tests.
Re: ip leack failed
I tested other 3 different VPN with standard browser (without WebRTC plugin and with SecureDNS enabled) and passed all test without show my real IP.
- khanyash
Check DNS tests here: https://browserleaks.com
HideAway will pass IP and DNS tests if you first connect to HideAway and then start the browser. I do not know if HideAway protects against the WebRTC leak or not, but yes, there is a WebRTC leak with HideAway.
Re: ip leack failed
I mean, with SecureDNS enabled in browsers, DNS tests will fail, i.e., show SecureDNS IP too.security_blog wrote: ↑Tue Apr 19, 2022 3:18 amI tested other 3 different VPN with standard browser (without WebRTC plugin and with SecureDNS enabled) and passed all test without show my real IP.
- nick.bolton
- The Big Cheese
- BBQs
Re: ip leack failed
I've run many tests over every site I can find to check IP/DNS I can find & there are no leaks, I was a little concerned after reading this post but not now - Tests run on on Hideaway are whole computer & PC started on whole computer - I have SecureDNS disabled on both my browsers Brave & New Edge - One thing to be aware of AVG/Avast will use their own DNS, this can be disabled though but can show as a leak. So no problems here.
- khanyash
You can test here https://browserleaks.com
Re: ip leack failed
Did you test for a WebRTC leak?BBQs wrote: ↑Sat May 14, 2022 9:19 pmI've run many tests over every site I can find to check IP/DNS I can find & there are no leaks, I was a little concerned after reading this post but not now - Tests run on on Hideaway are whole computer & PC started on whole computer - I have SecureDNS disabled on both my browsers Brave & New Edge - One thing to be aware of AVG/Avast will use their own DNS, this can be disabled though but can show as a leak. So no problems here.
- BBQs
Re: ip leack failed
Yes, I checked everything, I have browser leaks among several other similar sites on my bookmarks - I cannot find any leaks of IP/WebRTC - From my point of view any leaks would render using a VPN void, though as I have said I cannot find any issues, will check from time to time.
- khanyash
What connection type do you have? I use my mobile phone hotspot and can reproduce the WebRTC leak every time. I have another two VPNs and those do not leak WebRTC even if I do not block WebRTC in the browser.
WebRTC leak test
ipleak.net - No
browserleaks.com - Yes (Public IP address)
ipleak.org - Yes (Public IP address)
expressvpn.com - Yes (Public IP address)
Re: ip leack failed
Do you use AdGuard adblocker or any extension to block WebRTC in the browser?BBQs wrote: ↑Mon May 16, 2022 8:34 pmYes, I checked everything, I have browser leaks among several other similar sites on my bookmarks - I cannot find any leaks of IP/WebRTC - From my point of view any leaks would render using a VPN void, though as I have said I cannot find any issues, will check from time to time.
WebRTC leak test
ipleak.net - No
