Difficulty Connecting to "Redirect: Torrent Applications"
gmusgrave
Tue Nov 07, 2023 1:35 pm
Starting with the previous update, and continuing with the newest (4.20.2), I have a great deal of difficulty connecting to "Redirect: Torrent Applications."
I have to try anywhere from three to seven times before I get a solid connection. The way it fails is that within a second of connecting, the Latency number changes from some reasonable number to "-1".
Re: Difficulty Connecting to "Redirect: Torrent Applications"
Tue Nov 07, 2023 5:58 pm
Hi, restart HideAway and it will update to 4.20.3 and all will be good again
gmusgrave
Wed Nov 08, 2023 1:11 pm
It apears to be fixed! Thank you...
gmusgrave
Sun Nov 19, 2023 2:33 am
Uh oh.... it just broke again!!!
Sun Nov 19, 2023 5:50 am
Can you restart and update to 4.20.4
gmusgrave
Sun Nov 19, 2023 8:15 am
Seem Ok... for now...
trois
Mon Nov 20, 2023 11:07 pm
@nick.bolton
Same issue here, lately - I usually connect 'my computer' to Amsterdam - also for qBitTorrent (Nick mentioned that is a good (the best?) torrent-server/ISP). However, it's hit and miss, these days - if it runs (very well!), it 'suddenly' stops - is there a limit (minutes/hours or bandwidth (MB/GB))?
'Redirecting Torrent apps', I get that 'Latency -1ms' too.
It's not that my torrents are not uploading anymore, as disabling HA, they do (albeit, trickling). Also, changing the listening-port (in qBT) sometimes helps (> 60.000). At times restarting qBT helps, just not very often. My router reboots (almost daily) because of power-outages.
And yes, I updated yesterday to HA 4.20.4 (thankfully seeing this post).
What are A'dam-torrent-alternatives? I thought Milan worked reasonably well, in the past, yet it is barely connecting either.
Is it HA-servers getting limited/restricted? Some global ISP clamp-down on torrents?
It is just not as smooth and convenient any longer...
Tue Nov 21, 2023 3:59 am
4.20.4 should work well from now. Sorry we had our torrent hosts move data center and one by one they would have to migrate them over, and give new IP addresses, so this meant we'd have to keep issuing updates. We're done now so it should work fine.
trois
Tue Nov 21, 2023 6:19 am
What about a list of those IP's (encrypted....) on your server, that HA downloads once or twice a day (automatically, under the hood)?
That way we don't have to download the complete install (that I didn't get any notification about, but only learned about in this thread).
(wouldn't that be similar to FirstAlert in MW?)
Tue Nov 21, 2023 6:47 am
Yep, that's coming so we don't have to do these updates
