Hideaway not working?
sloppy33
Sat Nov 16, 2024 3:16 am
Hideaway is having a problem with all of my shortcuts, I cannot access any of them, the little cursor just goes round and round but doesnt connect, I even had problems with this forum, I could not connect unless I disconnect Hideaway. Please advise.
Re: Hideaway not working?
Sat Nov 16, 2024 3:28 am
Are you connecting via London? Just had an outage and fixing...
Sat Nov 16, 2024 3:55 am
Should be fixed now, but we might have some more temporary outages as the disk is failing so we need to migrate to some new server.
sloppy33
Sat Nov 16, 2024 4:25 am
Thank you Nick for taking the time to sort it all out.
sloppy33
Sat Nov 16, 2024 5:19 am
Down again. I will leave it off for now and use an alternative vpn.
Sat Nov 16, 2024 5:33 am
Should be up again now.
sloppy33
Wed Nov 20, 2024 2:32 am
Down again Nick, not really reliable at the moment. Is there any workarounds apart from getting another vpn.
Wed Nov 20, 2024 6:09 am
Was this Toronto? We had to take it down as someone was using torrents with it and causing lots of DMCA complaints, just trying to sort out that a the moment so it doesn't get suspended in the future.
sloppy33
Thu Nov 21, 2024 12:18 am
Nope this was London, using bitdefender vpn at the moment because I cannot even connect to you with Hideaway on.
Thu Nov 21, 2024 7:30 am
Seems odd, as it's working properly and we've not had any other users complain. Can you uninstall, restart your PC and then install HideAway again. I wonder if some update has interfered with HideAway
sloppy33
Fri Nov 22, 2024 1:11 am
This is disappointing, did as you instructed but now cannot dl the new Hideaway. It says Code execution. ffmpeg.dll was not found. contact the author. Had high hopes this time. Thank you for trying though.
Fri Nov 22, 2024 7:23 am
Odd, here's the ffmpeg.dll file to download. https://25fc482ddf92aa413bac-f38e90dc86 ... ffmpeg.dll
If you go to Windows>>Start. Type 'run' and press enter.
Then type
%localappdata%\HideAway\app-4.20.4
and press enter, it will open a folder. Add the file ffmpeg.dll in to there.
Start HideAway
Nick
sloppy33
Fri Nov 22, 2024 10:44 pm
I think I am getting in deeper with this problem, I did as you instructed but the link you sent would not dl because "it may cause harm to my pc." I tried dragging it over but did nothing to Hideaway. Still the same problem, with HA connected I cannot get my shortcuts to work, little circle just goes round and round, disconnect HA and up they all come. As rustic dog can probably confirm I am not tech savvy and do not feel confident about pressing this that and the other but this problem is really frustrating, I still have a year to go on my subscription.
Sat Nov 23, 2024 9:12 am
Ok, let me know if you want me to do it for you. If you want to Private message me on [email protected] and we can do it via www.anydesk.com
