MWP can no longer access the server.
dmb06851
Re: MWP can no longer access the server.
Tue Oct 04, 2016 4:39 am
Yes, both Yahoo and GMail were unable to connect to their servers.
That's been a waste of time. Uninstalled MWP again, including all settings/data. Reinstalled and used all the previous setting which had been in use for years.
Neither Yahoo or GMail will connect to the servers.
I'm wondering if Tweaking.com's Windows Repair (All in One) might help.
Tue Oct 04, 2016 4:49 am
It is a waste of time uninstalling and re-installing MWP — that is not going to help in any way.
BTW, did you check the connectivity after disabling your security system (including your firewall) temporarily?
Can't think of anything else.
dmb06851
Tue Oct 04, 2016 5:21 am
Ok. Well, I had to recreate both email accounts anyway.
Yes, I disabled all security programs and the firewall, and MWP still couldn't connect to the servers.
Tue Oct 04, 2016 5:42 am
Just tried POP3 on a Yahoo! account and had to make the following 2 changes (inclusive of these changes) — this is what worked for me:—
Right click (the above screenshot) >>----> hold down *Ctrl* key >>----> click *View Image* for the BIGGER picture
dmb06851
Tue Oct 04, 2016 12:25 pm
Thank you Trustfire, I've modified the settings as you suggested, but I'm afraid that hasn't helped. I have also experimented with the GMail settings, also to no effect.
Oh, a step in the right direction - perhaps.
I modified my GMail account to accept less secure applications and MWP now connects to the GMail server/s.
The latter due to having received email from Google saying that "Someone just tried to sign in to your Google Account ..... from an app (sic) that doesn't meet modern security standards."
Tue Oct 04, 2016 4:51 pm
Glad your Gmail problem is resolved. :thumbsup
As for your Yahoo! issue, let me know if you would like to try out IMAP instead of POP3.
dmb06851
Wed Oct 05, 2016 12:41 am
Yes Trustfire, I would.
Wed Oct 05, 2016 12:55 am
dmb06851, please check out the IMAP settings for Yahoo — not certain that they would necessarily work for you, but worth giving it a shot.
If you do not wish to have read mails from the past being displayed on MWP, you can un-check (disable) Download read e-mails, as illustrated at the following figure:—
dmb06851
Wed Oct 05, 2016 6:57 am
Tried that. After saving the changes in MWP, it reports Connection successful. However after Going to Inbox/Check Mail it doesn't connect.
The Event Log tells me:
"Description:
Failed to login to server "imap.mail.yahoo.com" for your Yahoo account
Diagnosis:
This could suggest the following problems:
- Your username or password is incorrect.
- The server address is incorrect.
- You are trying to connect through an invalid port."
Wed Oct 05, 2016 12:43 pm
You may need to 'Allow access for less secure apps'....?
https://help.yahoo.com/kb/SLN27791.html
dmb06851
Wed Oct 05, 2016 12:53 pm
I've done that gingbat, but doesn't help.
Wed Oct 05, 2016 1:21 pm
Possibly log into your Yahoo webmail page, and under Options>>Mail Options>>POP & Forwarding, ensure POP (and IMAP?) access is enabled....?
If you still get the message that your username/password is wrong, all else I can think of is to change it and see if MW allows the new password....?
dmb06851
Thu Oct 06, 2016 3:01 am
At last ..... it's working.
Despite the fact that MWP said that it successfully connected to the server after making a change in the settings, I decided to change the password anyway.
That has, at least for now, overcome the problem.
Thank you both for your efforts and time. It is appreciated.
Thu Oct 06, 2016 3:14 am
Phew! :mrgreen:
Thu Oct 06, 2016 8:12 am
I second that :)
