link to latest beta version
Re: link to latest beta version
Sat Aug 10, 2019 10:19 am
Thanks, it shows something is still blocking the driver installation unfortunately.
Sat Aug 10, 2019 11:59 am
Could you do this.
Run "Change User Account Control settings"
Move the slider to "Never notify"
Save
Run HideAway again
and Send Logs
Teljeur
Sun Aug 11, 2019 9:29 pm
After the windows 'çhecking for updates' the program stops.
log.log
(3.63 KiB) Downloaded 418 times
SquirrelSetup.log
(3.39 KiB) Downloaded 379 times
Mon Aug 12, 2019 12:49 pm
Alright, I think we have this sorted now
I tested it with SecureAnywhere before and after, and it's working properly now.
Teljeur
Mon Aug 12, 2019 9:46 pm
It works :-) After installing it updated to 4.2.1. HideAway could not run the driver because there was an uninstall in progress from the previous version. I had to reboot. After rebooting HideAway worked......
Good work!!
Mon Aug 12, 2019 9:58 pm
Excellent, thanks for confirming that. Now on to some features, and one more bug to fix.
