Introduction to regex filters
chantoine
Re: Introduction to regex filters
Sun Aug 29, 2010 10:00 pm
rusticdog wrote:
I've got 4 emails currently in my Inbox that shows this but it seems to be working so far, that said, I'm on a slightly different version than you.
There is a possible issue if the UTF8 encoding goes across multiple lines that breaks oddly, so I'll keep watching as they arrive.
Hello,
I too can't get filters to work when i have some french accentuated characters (ex. "é" "è" "à") in the string tested (object field).
HTH
Mon Aug 30, 2010 1:00 am
chantoine wrote:Hello,
HTH
OK, we'll get that fixed up.
guakamole
Tue Aug 31, 2010 3:35 am
The filters also don't seem to support Cyrillic characters... Just have run several tests, with negative results :(
As well as plain text filters...
chantoine
Sat Sep 04, 2010 6:24 pm
HTH
Is that fix planned for the release next week ?
This bug is very embarrassing for me : many of my mails have some accentuated characters in the object field...
Have a good WE and hoping everything if fine despite the earthquake !
Mon Sep 06, 2010 10:10 pm
chantoine wrote:Is that fix planned for the release next week ?
yes, we'll be doing our best to make sure this is included in the next release
chantoine
Mon Sep 06, 2010 11:16 pm
Thanks :D
chantoine
Sun Oct 17, 2010 1:26 am
Hello,
Juste downloaded 1.0.35 and the accentuated characters bug is still present :|
What is your correction planning ?
Thanks !
racker
Sun Oct 17, 2010 3:48 am
As long as this is not solved, you could work around this issue by ommitting the accented character. I've achieved this by splitting a filter in two lines, one controling the part of a word before an accented character, and another one for the last part. In my example I filter on the word "métaphore" .. and it works! (for me)! :)
Workaround for accented characters
Beta tester.. oh well! ;)..
MWP FAQ
chantoine
Sun Oct 17, 2010 4:57 am
Thanks,
This workaround can't work for me, because it's not about controlling a word containing an accentuated character, but controlling an expression with none (accentuated character) while such a character is present (for example in the object field) : in this case regex filter just don't work.
Thanks anyway !
Tue Oct 19, 2010 9:16 pm
Thanks !
Ok we'll take another look. We'd made a correction for one of the examples we had, but must have missed this.
chantoine
Thu Nov 11, 2010 6:54 pm
Thanks !
Just downloaded 1.0.40 and no correction with this bug !
Sorry, but for any user language with accentuated character, this is very annoying :-(
Thu Nov 11, 2010 8:09 pm
1.0.40 is newer that the beta testers have, can't help you there.
chantoine
Thu Nov 11, 2010 8:20 pm
stan_qaz wrote:1.0.40 is newer that the beta testers have, can't help you there.
Funny ! Why was i able to download it ?
Note : same behavior with 1.0.39 8)
Pierre
Thu Nov 11, 2010 8:24 pm
Type in 'Mailwasher 1.0.40' into Google and you get a lot of hits. Please do not trust these downloads :thumbsdown :thumbsdown :thumbsdown - the latest release is 1.0.35!!!! Only down load from the Firetrust website.
Thu Nov 11, 2010 8:30 pm
I see 39 as the latest beta but don't see 40 anywhere on the beta forum or on the main Firetrust site.
I don't even see your user listed as a beta forum member...
If you are grabbing random files off the web, well good luck!
1.0.35 is the latest version supported here until one of the Firetrust folks posts something newer.
