reply button fails
jimmww
Re: reply button fails
Mon Apr 03, 2023 6:34 am
Another reply button failure in MW with Tbird active, from a different sender:
Received: from o4239.e.email.meetup.com (o4239.e.email.meetup.com [167.89.53.166])
by imf24.b.hostedemail.com (Postfix) with ESMTP id 9BB4C80012
for <[email protected]>; Sat, 25 Mar 2023 12:03:16 +0000 (UTC)
Authentication-Results: imf24.b.hostedemail.com;
dkim=pass header.d=email.meetup.com header.s=s1 header.b="Z3+U/JxU";
dmarc=pass (policy=reject) header.from=meetup.com;
spf=pass (imf24.b.hostedemail.com: domain of "bounces+28368967-de59-xxx=[email protected]" designates 167.89.53.166 as permitted sender) smtp.mailfrom="bounces+28368967-de59-xxx=[email protected]"
ARC-Message-Signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=hostedemail.com;
s=arc-20220608; t=1679745796;
h=from:from:sender:reply-to:reply-to:subject:subject:date:date:
message-id:message-id:to:to:cc:mime-version:mime-version:
content-type:content-type:content-transfer-encoding:in-reply-to:
references:dkim-signature; bh=17EUBENcg/C1k8EI5cvCDhhJ8oocdLliJEnOJzTOkfo=;
b=vIxn0yockEPvfGsiPFYfDFoLtYR2xusclsNtB7+XWu4aNB4OwwYkfrSRZrNK1KT1SzKis2
Xc/f713lg4lJgh1F8F3tGxw3T24zizXYhGtciKgPYnWMEsDMYkPN3IyyZ01A8VUdu7nuML
i9BruwcHXZTO8ZcEvajPRpVPhYCCl1w=
ARC-Authentication-Results: i=1;
ARC-Seal: i=1; s=arc-20220608; d=hostedemail.com; t=1679745796; a=rsa-sha256;
cv=none;
b=r7jRLUg8XtabDUdAIMGJQWrs1dkRg4MY6uxIym5KphJ1p1TiFzOyOsQYi3eTBtYaxqQttd
khQAvuzUXttxt557MLquJG0uqsAR0ebvGJSWxX+PUVe0y4BJeLrFrssPb2ObsTxPnAAHGG
kTnQttaQ5mqugtJywLAqh/HP/9Ng93g=
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=email.meetup.com;
h=content-type:from:mime-version:subject:reply-to:to:cc:content-type:
s=s1; bh=17EUBENcg/C1k8EI5cvCDhhJ8oocdLliJEnOJzTOkfo=;
b=Z3+U/JxU1j2hyNmjGuNdXhTztEgw9C1A+z7F29XqkSlFfqd07opHEYJbNGu59S0Lkl1k
K6ufVaZM9z9fd2ntAprgATNbuY0ZfCht8VCrR/+f/XNScuLMuePhaNdPm4i0dkqOiWwXQy
AUaRB3PH0aPitaX/YnAsTN5E9mUEqYyDRcDuHYOv2/cLw2/Ya3DYcPwubTEhD+HlJPCrcU
YJnHw4BocPVXKhnTSb6GUSKELtz98UxDxgPUbrh0o0AQPRerrSsCiqQ94xc5ZoQVPkxH/H
795Hsv5lkZS08GEcciDStR4brZjs4bKXTAjm2KJKUdy9+8TpOwk6aj8XPgYeFHng==
Received: by filterdrecv-9486d7cc7-zlxsr with SMTP id filterdrecv-9486d7cc7-zlxsr-1-641EE303-AE
2023-03-25 12:03:15.478318423 +0000 UTC m=+2723329.445998542
Received: from MjgzNjg5Njc (unknown)
by geopod-ismtpd-23 (SG) with HTTP
id YRq4NKTYTKS6Ebp_tFPMIg
Sat, 25 Mar 2023 12:03:15.422 +0000 (UTC)
Content-Type: multipart/alternative; boundary=273e5e6468f010f27787cc4ff6a512a43eef63883e29e50dce177e6b99f6
Date: Sat, 25 Mar 2023 12:03:15 +0000 (UTC)
Mime-Version: 1.0
Message-ID: <YRq4NKTYTKS6Ebp_tFPMIg@geopod-ismtpd-23>
Subject: Reconnect with what you love about Portland =?UTF-8?B?8J+Sqw==?=
Reply-To: [email protected]
Thu Jun 08, 2023 6:34 am
Yes, the mail program/thunderbird button is only for opening TBird after washing mail, or sets MW to open that particular email program after washing mail, not related to the reply button itself.
That button simply opens a mailto link which should be opened by the default email client (which should be set to open mailto links) on your PC.
Try setting another email program as default in Windows, test the reply button in MW, if that works OK, go back and set your chosen email client as default in Windows, and see how that goes....?
