Brave leaks DNS while using HideAway
BBQs
Re: Brave leaks DNS while using HideAway
Sat May 27, 2023 4:52 am
Unfortunately, I still get DNS leaks to my ISP using Chrome Edge using for example https://ipx.ac/run - I don't get this issue with other VPN's I've tried including AdGuardVPN I'm using now or OVPN / IVPN / Bullet / Mullvad etc (tried these out of interest) -Sorry about this but, not sure where to go now with HideAway? If others are OK, looks like using an alternative VPN.
Sat May 27, 2023 7:07 pm
Hey thanks for the tests, interesting there's quite a few which don't detect it as a leak, but there's a couple which do, including the link you sent. We'll keep investigating.
BBQs
Sun May 28, 2023 7:06 am
When I have a minute tomorrow I'll check which sites show a leak & which don't - It's interesting that some well known sites for leak tests don't show a leak - In others opinion if I don't show any leaks on Firefox for example but do on Edge, am I OK using Firefox with Hideaway?
Sun May 28, 2023 10:17 am
Yes, I use Firefox and it works all the time well. When we first started HideAway, we found some of these dns leak sites (most are owned by other VPNs) would give a bit of false info to make their own VPN look better.
indie
Mon May 29, 2023 12:43 am
To my regret, Brave, Edge, Chrome - any Chrome based browsers are leaking.
Here is one test site:
https://www.perfect-privacy.com/en/tests/dns-leaktest
Another test site that clearly indicates my ISP DNS servers:
https://browserleaks.com/dns
And this one shows the leak:
https://ipleak.net/
Mon May 29, 2023 10:31 am
This fixes it.
https://25fc482ddf92aa413bac-f38e90dc86 ... -setup.exe
Close HideAway down before installing this version.
There were some non-standard DNS requests that we were ignoring since they were non-standard. Let me know how you get on
Mon May 29, 2023 9:18 pm
FYI, HideAway wasn't really leaking, it was just showing the DNS sever used by the ISP, not your real IP. Because A/AAAA records were being done correctly but those testing websites use non-standard DNS record types to test their leak, and one of those we were skipping because it's non standard.
indie
Tue May 30, 2023 12:58 am
Thank you very much.
No more DNS leaks.
Now, we are back in business.
Thank you.
BBQs
Wed May 31, 2023 12:37 am
He's only gone & fixed it! :lol: :lol: :lol: Thank you
indie
Wed May 31, 2023 2:55 am
It looks like my yesterday's happiness was short-lived. :(
Here are the new Brave tests today.
From https://www.dnsleaktest.com/results.html
It shows only(!) my ISP DNS. Nothing to do with HideAway. :cry
DNS test.png (47.22 KiB) Viewed 12799 times
Here is my Brave test from https://browserleaks.com/dns
DNS test-2.png (38.02 KiB) Viewed 12799 times
BBQs
Wed May 31, 2023 5:23 am
For me the problem occurred on a couple of sites which showed 'Virgin Media' my ISP while running HideAway - The latest release (4.40.1) has solved the issue on every site I've tried it on - I've tried it on all the 'leak' sites I have.
indie
Thu Jun 01, 2023 5:37 am
Some interesting facts.
I have three computers connected to my local network (no domain.)
And only one computer with Chrome-based browsers is leaking.
The other two are not leaking my ISP DNS while using Chrome-based browsers.
It's really strange, because all my computers - different models but with Windows 11 - have the same Bitdefender AV, the same browsers, the same extensions.
g6radio
Thu Jun 01, 2023 11:34 am
If you want to experiment with a chrome based browser, try ""ungoogled chromium"
Version 112.0.5615.138 (Official Build, ungoogled-chromium) (64-bit)
It seems to be very fast and is claimed to be free of google junk.
Extensions are a bit tricky to install but i am very impressed so far.
Maybe give it a try and see if the problem still exists
Info here https://ungoogled-software.github.io/un ... m-wiki/faq
https://github.com/NeverDecaf/chromium- ... e/releases
https://avoidthehack.com/manually-insta ... d-chromium
https://avoidthehack.com/how-to-install ... extensions
place123
Thu Aug 24, 2023 5:43 pm
Since the Secure DNS option in Brave doesn't seem to be doing the trick
Go ahead and manually set up a secure DNS server in your browser's security settings. Give Cloudflare, NextDNS, or Google's DNS servers a shot. This could be your ticket to stop those pesky ISP DNS leaks when using HideAway for where am i.
