EMails are not showing in the list unless I restart MWP
Re: EMails are not showing in the list unless I restart MWP
Tue Nov 07, 2023 6:25 am
Yes, pretty odd alright, if POP is also behaving oddly, we should have a new version out soon which supports OAUTH so you wont need to use an app password, possibly that'll help here... no date yet though, just waiting for Google......
LePousson
Tue Nov 07, 2023 6:32 am
Not sure that it comes from the OAUTH thing not present as all the other accounts are also set using "app password" and they work perfectly ... This is totally weird and I have moved the mails from this account to another one which is working. I'll keep this account for any later try ...
Karrenbrady
Wed Nov 08, 2023 8:06 pm
Should I choose an ENERGY STAR-Qualified ceiling fan?
Every home or workplace needs ceiling fans to maintain a comfortable temperature and promote air circulation. Although many might not be aware, ceiling fans play a significant role in energy conservation. They are a great method to reduce summertime air conditioning consumption, which can result in significant energy bill savings. But only some ceiling fans are made equally. In this case, ceiling fans with the ENERGY STAR label are helpful.
An ENERGY STAR-Qualified Ceiling Fan is what?
It was created to make it simpler for buyers to locate products that respect the environment and use less energy. ENERGY STAR certified ceiling fans must meet stringent EPA energy efficiency requirements. These laws guarantee ceiling fans are up to 60% more energy-efficient than standard fans, which can aid with energy, environmental, and financial savings.
Benefits of Choosing a Ceiling Fan with the ENERGY STAR
Power Savings
Regular fans use less energy than ceiling fans that have received the ENERGY STAR certification. They can drastically lower your energy costs by consuming up to 60% less. The EPA estimates that an ENERGY STAR-certified ceiling fan can reduce annual energy costs by about $15. These savings have the potential to grow substantially over time.
Environmentally Friendly
Environmentally friendly ceiling fans are those that have earned the ENERGY STAR label. They are created with environmentally friendly materials and cutting-edge technology, lowering carbon emissions. By choosing a ceiling fan that is ENERGY STAR certified, you may reduce your carbon footprint and help to safeguard the environment.
You might also enjoy: Ceiling Fans Living: Best ceiling fan products
Enhanced Comfort
The ENERGY STAR-certified ceiling fans are designed to move air more efficiently. They move air more efficiently, increasing comfort in your house or business. As a result, you won't need to rely as heavily on air conditioning to enjoy a more pleasant home or workplace. Your energy use will consequently decline, as will your energy costs.
Superior Performance
The ENERGY STAR labeled ceiling fans are designed to meet exacting EPA performance standards. They are durable and dependable since they are constructed with top-notch materials and energy-saving technology. This implies that you won't need to worry about the performance or upkeep of an ENERGY STAR-qualified ceiling fan for a long time.
Better Lighting
Many ceiling fans that are ENERGY STAR certified have built-in lighting options. These lighting fixtures use energy-saving LED bulbs, which can save energy costs and enhance the lighting in your home or business. Since LED bulbs last very long, you won't need to replace them as frequently as you would with conventional bulbs.
Reasons to Take into Account Buying an ENERGY STAR-Qualified Ceiling Fan
Cost reduction
One of the most important things to take into account when choosing an ENERGY STAR-qualified ceiling fan is cost savings. Up to 60% less energy is used by ceiling fans with the ENERGY STAR label than by regular fans, which can save you money on your energy bill. These financial savings have the potential to grow substantially over time.
Environmental Advantages
Another eco-friendly choice is a ceiling fan that has earned the ENERGY STAR label. The more energy-efficient design of these fans contributes to decreased carbon emissions and environmental protection. You may contribute to preserving the environment by selecting a ceiling fan that has earned the ENERGY STAR certification.
⫸⫸⫸  See also: Why spend a lot of time when reading many reviews before buying, CeilingFansLiving will help you save time and money!
Enhanced Comfort
The degree of comfort in your home or business can be raised thanks to ceiling fans that have earned the ENERGY STAR certification because they are made to circulate air more effectively. Reducing air conditioning will result in more comfortable living or working conditions. Your energy usage can be decreased, resulting in cheaper energy costs.
The ENERGY STAR labeled ceiling fans are made of high-quality materials and use energy-saving technology. They are trustworthy and durable, which can help you save money over time on maintenance and replacement costs.
Better Lighting
Many ceiling fans that have earned the ENERGY STAR label include energy-saving LED bulbs built into their built-in lighting systems. These bulbs have a long lifespan and can lower your energy costs while enhancing the illumination in your house or place of business.
In conclusion, buying an ENERGY STAR-certified ceiling fan is a great investment to save energy costs, protect the environment, increase comfort, and get high-end performance. Making the right choice for your ceiling fan will benefit your money and your house.
Related post: Ceilingfansliving: Best Ceiling Fan Review
LePousson
Thu Nov 09, 2023 5:04 am
I already checked all the other accounts and they are 100% set up like all the others (except the credentials of course) ... This is just amazing and I have no time to waste at now trying to fix this thing that might also come from a problem directly at GMail/Google ...
