WailWasher Reverts to Trial/Wash Button Problem
anniebrion
Re: WailWasher Reverts to Trial/Wash Button Problem
Thu Jul 15, 2010 3:19 am
Here's the setting:
Thu Jul 15, 2010 3:20 am
cfheinz wrote: I don't understand the first option, but had planned to do the second if the problem persisted.
I don't recall the former as something in the Settings, but will take another look.
The setting is here:
MWP Check on Start.png (32.23 KiB) Viewed 7356 times
cfheinz
Guardian Gecko
Thu Jul 15, 2010 3:29 am
Thanks. I'll leave it as is for the present, but will include it if the problem persists.
If so, should I send separate log?. The first after the restart and MWP has reverted to "trial" mode. The second after having turned off the check at start but following another cold start.
Carl Heinz
Thu Jul 15, 2010 4:24 am
Usually MW will send in the full set of logs for the day that you send in the report so you can beat on it for a while and send in the full set of logs. The option to view just what is being sent is offered in the log sending screen too. I like submitting my logs via Gmail as that gets me a copy of the message there that I can go back and look at later.
Sometimes if I've been doing a lot of mail washing I'll go to the user files section, exit MW and rename the day's log folder and then restart MW to get a fresh set of logs to send in with just the problem in it. Not really necessary but I figure if rusticdog goes blind from log reading I'll have to figure out how to submit them in Braille. :-)
cfheinz
Guardian Gecko
Fri Jul 16, 2010 2:30 am
Everything worked as it was supposed to this morning. The WiFi connect was made before the MWP start.
I'll continue monitoring and will send logs if the problem reoccurs.
I do think that the WiFi connect after MWP start is the problem.
Carl Heinz
cfheinz
Guardian Gecko
Sun Jul 18, 2010 2:44 am
I'm unable to reproduce the problem a third time. It appears that MWP did start before WiFi connect, but everything worked fine. I installed the new version when I received the notification.
Carl Heinz
Sun Jul 18, 2010 2:54 am
cfheinz wrote:I'm unable to reproduce the problem a third time. It appears that MWP did start before WiFi connect, but everything worked fine. I installed the new version when I received the notification.
I think this will fix the problems when the WiFi starts after MailWasher, the programmer had some embarrassing logic in place that would mean Wash Mail would not enable if MailWasher started with no internet access. He is very sorry about that.
cfheinz
Guardian Gecko
Sun Jul 18, 2010 6:53 am
Having been a Senior Programmer/Analyst for nearly 30 years, I know the feeling. :)
Carl Heinz
