Fri Jul 29, 2016 5:33 pm
Changes at the foot of the Private Messaging section:—
  • Themed the 2 Option Boxes.
  • Stripped-off elements which I never use.
  • Reduced some inequitable gaps.
  • Gained vertical real estate.
Fri Jul 29, 2016 11:08 pm
QuietOne wrote:
TrustFire wrote:Have reproduced the issue, you encountered — as mentioned above, the fault lies at the Preview Pane (have rectified it at my end)
Yeah, it looks like you're right about the Preview Pane being the culprit. :thumbsup :thumbsup :facepalm :devil
Have also widened the Preview Panel to match my extra-wide Posting Area as per tweak # 1 and tweak # 2.
Sat Jul 30, 2016 1:14 am
TrustFire wrote:Changes at the foot of the Private Messaging section:—
Provided the "metro" look HAS TO BE, then the "After" is better than the "Before". :facepalm :thumbsup
Sat Jul 30, 2016 1:17 am
TrustFire wrote:Have also widened the Preview Panel to match my extra-wide Posting Area as per tweak # 1 and tweak # 2.
:thumbsup :thumbsup
Sat Jul 30, 2016 2:56 am
Changes:—
  • Returned the Avatar to its rightful place.
  • Reworked all gaps for (horizontal as well as vertical) equilibrium.
Sat Jul 30, 2016 3:28 am
TrustFire wrote:Changes:—
JM2c but the Avatar et al belongs on the RIGHT :thumbsup side, not the left. :nono :thumbsdown
All the rest :thumbsup :thumbsup
Sat Jul 30, 2016 3:33 am
Outside of this theme, have never come across a Board in my lifetime where the Avatar was on the right side — perhaps you can point me to one. :scratch
Sat Jul 30, 2016 3:36 am
Spend the vast majority of my "board time" on this forum so can't rightly think of any exceptions to it. Thus the reason I prefer RHS Avatars. :dunno :devil :devil
Sat Jul 30, 2016 3:40 am
:mrgreen: :mrgreen:
Sat Jul 30, 2016 3:50 am
User Control Panel Inconsistency ...
Sat Jul 30, 2016 5:21 pm
At this point in time, the Present Board over-exceeds the Previous Board in almost all aspects, at least on my systems.
Sat Jul 30, 2016 6:41 pm
On a unrelated note, while glancing at the following screenshot — the color on the following 2 tiny, dark little icons are (surprisingly) the ones that strike me as the most prominent. :think
Sun Jul 31, 2016 5:14 am
TrustFire wrote:On a unrelated note, while glancing at the following screenshot — the color on the following 2 tiny, dark little icons are (surprisingly) the ones that strike me as the most prominent. :think
How so??? :scratch From my POV they're too small to stand out so extremely over the balance of the info on the screen. :scratch :scratch
Sun Jul 31, 2016 6:13 pm
Despite being small, the incorrect coloring of those 2 icons distracts the eye:—
  • The color of those Read Messages icons are dark when they should be light
  • The color of the Active Menu is light when it should be dark
  • The color of the Active Tab is light when it should be dark
  • Header font is Regular when it should be Bold.
Shall work on the PM section when time permits. :think
Mon Aug 01, 2016 2:54 am
Damn . . . . . . the following 4 buttons have regressed to their original state — or, is it only me:—
  • Edit
  • Delete
  • Report
  • Quote
