Android MailWasher No Longer Syncing?
Re: Android MailWasher No Longer Syncing?
Thu Feb 01, 2024 7:18 am
Yes, fixed in the beta... so let us know if you want to try this....
emmrecs
Sun Feb 04, 2024 10:59 pm
Since MW Mobile has failed to sync for me since February 1st, 19:00 GMT, under both Android and iOS (iPad) is installing the beta the only way to resume “normal service”?
If so, how does one get it?
Mon Feb 05, 2024 6:00 am
Yes, that is correct, please see:
viewtopic.php?f=55&t=17702&start=15#p171347
statman
Sat Feb 17, 2024 9:14 am
Can't log into MW for Android. Was working fine this AM but now asked for login then loops, want login?
Statman
Statistical Services
Florida, USA
Windows 10/11
[Web Site](https://zstatman.duckdns.org/)
"No one cares how much you know until they know how much you care" [Unknown author]
statman
Sat Feb 17, 2024 10:42 am
Well, not sure the reason but logged in and all seems fine
Statman
Florida, USA
Windows 10/11
Sat Feb 17, 2024 11:39 am
Yep, was broken overnight, fixed now... :)
au.ifiX
Fri May 03, 2024 4:02 pm
Hi FT,
Experimenting with MW mobile and syncing and have an error logging in in MWPro, with this log extract.
05-03-2024 13:39:47.149 MWPUI Error logging in
05-03-2024 13:39:47.149 MWPUI Unable to find an entry point named 'MWReqClearHeaders' in DLL 'mwreq.dll'.
05-03-2024 13:39:47.149 MWPUI at MailWasherPro.SyncLogin.MWReqClearHeaders()
at MailWasherPro.SyncLogin.SendRequest(String Url, String Data)
at MailWasherPro.SyncLogin.ProcessNewLogin(LoginDetails info)
at MailWasherPro.SyncLogin.ProcessLogin(LoginDetails info)
Fri May 03, 2024 6:07 pm
Yes, sorry about that, please email support for a beta version you can use until we get the release out to fix this issue....
support at firetrust dot com
Hopefully wont be too much longer before a update is ready!
au.ifiX
Mon May 13, 2024 3:12 pm
Many thanks, will do. :)
Chariott
Sat Nov 16, 2024 6:40 pm
Any update on the release version?
Sun Nov 17, 2024 5:36 am
Do you mean the login issue from MWPro to MW Mobiles database? if so, yes, should be working fine in the current 7.15.10 version now....?
Chariott
Mon Nov 18, 2024 4:50 am
I'm using version 7.15.10 of MW now and have been. I'm using version 2.0 of MW mobile on my android phone and have been since that version became available. I have not been able to sync my email accounts since this thread began.
I was hoping a new version of MW mobile would become available.
Mon Nov 18, 2024 8:52 am
Yes, updated MW Mobile looks like it wont be for quite some time sorry, re the sync however, what accounts are not working? note that it wont work with any Microsoft based accounts now that they have stopped plain text password access to these, they only allow access via OAUTH which MW Mobile does not yet support....
Chariott
Tue Nov 19, 2024 4:36 am
Sorry to hear that.
All of them. I only use sync between MW and MW mobile, and MW mobile is not working. My primary email accounts are with comcast.net. I have a Google account, several AOL accounts, and several earthlink.net accounts. At present, none of them sync with MW mobile.
Tue Nov 19, 2024 6:51 am
OK, just tested AOL and Gmail although MWPro still says they dont, they do sync fine, if you are using App passwords in MWpro they 'should' sync to MW Mobile via Settings>>Sync, check the accounts and click Sync...?
If problems, try syncing one account at a time?
Email support at firetrust dot com with the MWM account details and I can check your account if still problems?
