Mon Aug 01, 2016 3:09 am
TrustFire wrote:Damn . . . . . . the following 4 buttons have regressed to their original state — or, is it only me:—
  • Edit
  • Delete
  • Report
  • Quote
Mon Aug 01, 2016 3:58 am
Can you check the size of those 4 buttons after ensuring that your cursor is not within any part of the Post.
Mon Aug 01, 2016 4:04 am
TrustFire wrote:Can you check the size of those 4 buttons after ensuring that your cursor is not within any part of the Post.
Can't do "ALL 4 buttons" but can do "3 buttons": :devil
Mon Aug 01, 2016 4:29 am
Ah, there you go — your illustration clearly shows that the buttons have regressed to their original small size (when the cursor is not within any part of the Post.).
Mon Aug 01, 2016 4:45 am
TrustFire wrote:Ah, there you go — your illustration clearly shows that the buttons have regressed to their original small size (when the cursor is not within any part of the Post.).
So what does that matter??? :scratch :crazy They enlarge themselves when a person attempts to access them, which makes sense as, in that larger state, they become more easily accessed. :thumbsup :thumbsup When a user doesn't attempt to access them they decrease in size and become less "eye-catching" therefore allowing the user's eyes to more easily gravitate to what is important - the post. Again :thumbsup :thumbsup
So what's the problem???? :scratch :scratch
Mon Aug 01, 2016 5:35 am
What you state, was the original behavior of those buttons.
After we complained about the weak presence of the icons (at unfocused state,) the behavior was changed at server-level to a constant, prominent size — regardless of the state of focus they have now again started decreasing in size (hence the regression.)
Mon Aug 01, 2016 5:53 am
OK, now I remember. Must be getting old. Damn! :? :facepalm
Well, not sure it makes a great deal of difference now that I've played with it a bit more. :dunno But whatever toots your whistle, as long as the buttons are:
  • Always present when they SHOULD be; and
  • Work as advertised (i.e. perform their requisite functions). :devil :devil
Mon Aug 01, 2016 7:02 pm
  • Edit
  • Delete
  • Report
  • Quote
Good to see that Admins. fixed this regression on the server. :thumbsup
Mon Aug 01, 2016 7:52 pm
Mon Aug 01, 2016 9:37 pm
TrustFire wrote:Shall work on the PM section when time permits. :think
Changes:—
  • Changed a couple of Menu Headers from Sentence Case to Title Case.
  • Styled the Inactive Menus.
  • Changed the background color of the Active Menu.
  • Changed the Panel Title Size and Type in consonance with other Captions.
Tue Aug 02, 2016 3:18 am
Changes:—
:thumbsup :thumbsup
Tue Aug 02, 2016 7:45 pm
Styled the Board Notice as per the Board standard — and, changed the case on the Caption from Capitals to Topic Case.
Wed Aug 03, 2016 7:26 pm
One of those rare HTML moments when you stumble across such a thoughtless waste of precious vertical and horizontal real estate, as well — at the PM:—
Wed Aug 03, 2016 7:28 pm
The PM screen layout will be fixed next forum update as well, was an issue in the theme itself causing that.
Wed Aug 03, 2016 8:53 pm
OK good, have just started on the PM section myself — in the meanwhile whenever you need any help with the codes, do let me know. :thumbsup
