Wed Aug 03, 2016 11:06 pm
TrustFire wrote:Damn . . . . . . the following 4 buttons have regressed to their original state — or, is it only me:—
  • Edit
  • Delete
  • Report
  • Quote
The regression has happened . . . . . . . . . . . again. :lol:
Thu Aug 04, 2016 1:14 am
TrustFire wrote:One of those rare HTML moments when you stumble across such a thoughtless waste of precious vertical and horizontal real estate, as well — at the PM:—
:roll: :facepalm :crazy :thumbsup :thumbsup :devil
Thu Aug 04, 2016 2:04 am
Some more distinction between Read and Unread Posts — bringing some harmony to the Arrow Heads:—
Thu Aug 04, 2016 3:32 am
TrustFire wrote:Some more distinction between Read and Unread Posts — bringing some harmony to the Arrow Heads:—
Harmony is indeed a "Good Thing" :thumbsup but I'm STILL not enamored of your choice(s) for the icons on the left :nono :nono (and that's got nothing to do with them being Metro-ish). :no There's simply NOT ENOUGH contrast between them. :facepalm
Fri Aug 05, 2016 5:03 am
Changes for the PM Preview:—
  • Got rid of the dark background.
  • Reduced the size of the text on the Preview Header.
  • Added the prefix gap to the Preview Header.
  • Equalized vertical and horizontal gaps to match the gaps at the Forums Post area.
  • Matched the PM Preview outline to the one on QuoteTags and CodeTags.
  • Widened the entire PM Preview (thanks to tweak # 1 and tweak # 2.)
Fri Aug 05, 2016 7:37 am
TrustFire wrote:Changes for the PM Preview:—
Like the PM Preview :thumbsup but STILL have difficulty viewing the Green on Dark Gray :facepalm :facepalm in your Sig (and everybody's for that matter). :thumbsdown :thumbsdown It's the "Metro"-thing again. Not enough CONTRAST! :nono :nono :facepalm :bs :rant
Fri Aug 05, 2016 6:59 pm
Good to see the Blink Button back. :thumbsup
Also, good move . . . . . . introducing the 2 new Buttons — Spoiler and Sup (have changed their case, too.) :thumbsup
Glad that with all the above inclusions, frequently used Post Buttons continue to fit in a single row (for me) — in fact, there's place for even more.
Sat Aug 06, 2016 12:53 am
Just about to format a brand new DELL laptop (with OEM Windows 10) and after multiple people viewed and ratified these images — just like me, they could not find the contrast problem that you report (with the green on charcoal gray.) :no
Sat Aug 06, 2016 9:07 am
You aren't looking very hard! :nono :nono :facepalm
Sat Aug 06, 2016 1:41 pm
Oh yes, that's exactly the one, I (and the others) were referring to — BTW, that looks like a browser not fully optimized for font-rendering (hence the issue on your side.) :idea:
Sat Aug 06, 2016 2:35 pm
QuietOne wrote: You aren't looking very hard! :nono :nono :facepalm
OK, so here my browser font settings and they're already optimized about as far as I can optimize them.
And I've tried the "Use System Colors" setting BELOW both Checked & UN-Checked -- w/ No Difference. :nono
Sat Aug 06, 2016 8:54 pm
QuietOne wrote:OK, so here my browser font settings and they're already optimized about as far as I can optimize them.
This theme uses the FontAwesome family which has poor definition between the attributes.
Firstly, your Firefox is using FontAwesome because you have ticked (enabled) Allow pages to use their own fonts, instead of my selections above — so, un-tick (disable) it to begin the optimization.
Change your Proportional type from Sans to Sans Serif — it improves readability (but — only on the web.)
Opt for any standard and universal font on rest of the 3 fields and you'll find a lot of difference — Helvetica, Verdana or Tahoma are fine examples (play around with those 3 to find your poison — but, choose only one from among those 3.)
Change 20 to 16 — please note, all above changes will be global (meaning — the effect shall not be limited to Firetrust.)
QuietOne wrote:And I've tried the "Use System Colors" setting BELOW both Checked & UN-Checked -- w/ No Difference. :nono
Better to leave those settings alone — they are meant for the severely impaired and semi-blind.
Sun Aug 07, 2016 2:21 am
RE: This part of your reply ONLY ...
Why do you think I've been bitching as much as I have been about the color scheme etc.????? :scratch :toetap
While I'm NOT blind, I DO have a reasonably significant visual impairment!!!! (courtesy of Uncle Sam) :ninja :facepalm :| The damn color scheme (i.e. the Metro-look - the Dark Gray) DOESN'T, repeat DOESN'T, make it easy for me to see the damn forum.
RE: the rest of your reply ...
I'll try 'em (except the 16-20 font size biz) and see if it helps. Thanks! :thumbsup :thumbsup :devil
Sun Aug 07, 2016 2:40 am
The NEW Settings:
OK, played wioth the settings (including reducing the font size) but gained NO Improvement. :nono :nono Left ALL the settings as shown above but it's still Insufficient Contrast!
Sun Aug 07, 2016 3:14 am
Changed the Topic Tools from Sentence Case to Topic Case:—
