schnief
Prudent Pukeko
Location: How can you be in two places at once when you're not anywhere at all?
Sun Aug 14, 2016 2:07 am
TrustFire wrote:Glad you could join us — just working on your custom color preferences and shall be posting some illustrations on the same. :thumbsup
Wow! Super. Thanks very much.
MWP on nine computers, six with Win 10 Pro 2H22 x64 and three with Win 7 Pro SP-1 x64. All have Norton Security.
Sun Aug 14, 2016 2:55 am
Have made the color of the font on the Inactive Buttons lighter wherever applicable on the Board — (the codes have been rolled-out to all participants) here are a couple of examples :—
schnief
Prudent Pukeko
Sun Aug 14, 2016 3:20 am
TrustFire wrote:Have made the color of the font on the Inactive Buttons lighter wherever applicable on the Board — here are a couple of examples (the codes have been rolled-out to all participants):—
Great!
By the way, it appears that the "Font Colour" function doesn't work: the only choice is white!
Sun Aug 14, 2016 3:48 am
Take Note of the two SC's and the DropDown Menu. There are three (3) Menu Options listed on BOTH Menus but ...
Only the first two (2) can be seen/read REGARDLESS of whether the option is highlighted or not. The BOTTOM Menu Option can only be read if/when it is Highlighted! Need to make ALL THREE (3) Menu Options readable REGARDLESS of highlight status.
UN-Highlighted Menu Option:
Sun Aug 14, 2016 4:12 am
No Friends List available when creating PM's.
Sun Aug 14, 2016 4:27 am
schnief wrote:By the way, it appears that the "Font Colour" function doesn't work: the only choice is white!
Resolved the Color Palette issue.
Sun Aug 14, 2016 4:45 am
QuietOne wrote:Take Note of the two SC's and the DropDown Menu. There are three (3) Menu Options listed on BOTH Menus but ...
Strange . . . . . . . . I don't have the (3rd) grayed sub-menu, on your screenshot. :scratch
Sun Aug 14, 2016 4:47 am
QuietOne wrote:No Friends List available when creating PM's.
I see — shall have to create another account to resolve this one. :P
Sun Aug 14, 2016 5:27 am
Issue resolved at my end and codes updated to the server — hope it's resolved at your end, too. :thumbsup
Sun Aug 14, 2016 6:17 am
Friends List has no Scroll Bar.
Sun Aug 14, 2016 6:21 am
QuietOne wrote:Friends List has no Scroll Bar.
What happens if you disable this Green Theme. :think
Sun Aug 14, 2016 6:40 am
Notice several differences (anomalies vs bugs - you decide) RE: PasteBin as follows:
1) Calls me a "Guest" so not sure if I'll end up having to create an account myself;
2) .css filename is different. Will that cause/create a problem in the long run???
3) PasteBin is nagging me about using Ad-Block (Pro) and wanting me to buy a Pro account;
4) If I click the "paste" button, the display switches over to a file list but didn't see clearly what/where I was in the file/folder structure. Used the back button to get back to the code window display.
Whether or not any of this will make any diff top you and your needs are beyond my pay grade at the moment (since I'm only playing debugger). You decide if any of it is important to your needs.
Here's the SC.
Sun Aug 14, 2016 6:50 am
QuietOne wrote:Notice several differences (anomalies vs bugs - you decide) RE: PasteBin as follows:
Here's the SC.
1) No need to register for an account unless you want to.
2) The change in name of the CSS file does not affect in any way.
3) No need to buy anything — I'll disclose the blocking-codes to pimp the PasteBin site, too.
4) You just need to scroll down to the very bottom and copy the codes from the box reproduced below:—
Sun Aug 14, 2016 6:58 am
OK, here's the steps I went through and a new SC.
1) While Green Theme (GT) enabled, went to Compose message (No Scroll Bar);
2) Disabled GT and refreshed screen w/ essentially No Change (only change was a little font size & spacing variation but still no Scroll Bar);
3) Closed Firefox and then restarted FF;
4) W/ GT still disabled after restart Friends List was still same (No Scroll Bar);
5) Re-enabled GT and refreshed screen, still no scroll bar;
6) Restarted FF and returned to Compose Message, still no Scroll Bar.
Sun Aug 14, 2016 7:04 am
Yep unfortunately, that's a bug inherent with this new Board (at the PM section) — related to the one which rusticdog was referring to. :(
