Thu Mar 23, 2017 4:01 am
Encountered the following persistent error each time I tried to post in the Windows Update topic (Beta Channel):—
Thu Mar 23, 2017 12:16 pm
Guess it's all good now, there is a bug on another system on the same server that seems to occasionally chew up the disk space, techs are working on that. Seems to only happen once every few months.
Thu Mar 23, 2017 5:18 pm
It's all good now. :thumbsup
Sat Mar 25, 2017 2:13 am
Changes — The Alert Box:—
  • Re-colored the text
  • Re-colored the background
  • Optimized code for the forums
Uploaded the updated codes to the server. :thumbsup
Thu Aug 10, 2017 4:22 am
Just noticed that the sites is now https — hurray! :mrgreen: :thumbsup
smart1960
Thu Aug 10, 2017 4:30 am
:thumbsup :thumbsup :thumbsup :thumbsup :thumbsup :thumbsup :thumbsup :thumbsup :thumbsup to https://
Digerati
Retired Microsoft MVP
Tue Sep 12, 2017 3:06 am
When I try to enter the "approximately" symbol as found on the uppercase "tick" (reverse single quote) key (to the left of the 1 and ! key on a standard US keyboard), I get a slightly superscripted, slightly enlarged hyphen.
That is, I get this: ~
Note a real hyphen is this: -
Even when entering as an ASCII character 126, I get that weird hyphen.
Yes, I know a real approximately key is two squiggly lines ( ≈ ) as found with ASCII character 247, but keyboards don't have that for some reason.
So if I wanted to say approximately 50, it displays as ~50 instead of:
I have no problem using that key anywhere else.
Image Bill (AFE7Ret)
Freedom is NOT Free!
Pierre
Sun Nov 12, 2017 10:32 pm
FF updated with new version of Stylish 3.0.1. This will erase the previous 2 settings for Firetrust forum. I have installed the latest css files and it is working fine on both my PCs. Please use the css files as I am unable to attach them (invalid file). Sorry about that. Maybe Trustfire is able to help out in that department. :thumbsup
Mon Nov 13, 2017 7:45 am
Pierre wrote:FF updated with new version of Stylish 3.0.1.
Good catch. :)
Pierre wrote:This will erase the previous 2 settings for Firetrust forum.
Thanks for the heads up. :thumbsup
Pierre wrote:I have installed the latest css files and it is working fine on both my PCs.
The 3.0.1 is not working on my legacy copy of Firefox — must be working on yours probably since you might be using a WebExtension Firefox? :scratch
Pierre
Mon Nov 13, 2017 10:01 am
Good catch. :)
I am running FF 56.0.2 (64-bit). Does that cover WebExtension? The grey matter up top is starting to slow down a bit at my age. :) :) :)
I have attached the required css files in zip format. :thumbsup
Green theme - Firetrust.zip
(5.28 KiB) Downloaded 1088 times
Mon Nov 13, 2017 7:44 pm
Well, the 56.0.2 is the latest stable legacy build — I'm on the V56 Nightly and tried the 56.0.2, too but it's just not working for me (not working for many others, too.) :(
Guess would just have to wait for an update — until then, have downgraded to Stylish 2.1.1.
Sat Nov 10, 2018 10:31 am
For those interested, have optimized the custom green theme rules for Stylus — it's far better than stylish. :thumbsup
Mon Nov 12, 2018 7:16 pm
Was trying to PM someone a .png image which was just 307 KB — the Editor on my Messenger refused to allow uploading of the attachment, throwing-up the following error:—
Mon Nov 12, 2018 7:24 pm
TrustFire wrote:Was trying to PM someone a .png image which was just 307 KB — the Editor on my Messenger refused to allow uploading of the attachment, throwing-up the following error:—
Increased to 512. I have a lower limit for PMs due to a spammer that sent some users viruses.
Mon Nov 12, 2018 7:35 pm
Oh, I see — thank you, rusticdog! :thumbsup
