time format
schlieph
time format
Thu Aug 11, 2011 9:01 am
i just ran mailwasher 2011 v1.2.0 and noticed that PM time is incorrectly displayed.
there doesn't appear to be settings within mailwasher pro to address this. am i missing something?
PM time should be 16:42, not 04:42
mwpro - incorrect time format.jpg (14.76 KiB) Viewed 3420 times
Re: time format
Thu Aug 11, 2011 9:12 am
You posted this in the:
General Tech. Help
It properly belongs in the MW 201X forum: http://forum.firetrust.com/viewforum.php?f=50
I believe MW takes the date format from Windows, mine look correct.
If that isn't it try asking in the 201X forum and give the folks there Your Windows version and version of MW. you might also try the latest version posted there and see if it fixes your problem.
schlieph
Re: time format
Thu Aug 11, 2011 9:38 am
it properly belongs nowhere because i screwed up my regional settings the other day .. used hh instead of HH and got back to the 12-hour clock.
thanks for your reply.
