Questions : "Français Québécois/Canada""Français".
Mon Aug 29, 2011 3:19 pm
OK great, many thanks Sylvain and sorry too for the delay.
Do you think it appropriate we also remove Canadien Français from the list of languages and just have the single Français ?
SSTSylvain
Modérateur française
Re: Traduction: "Français Québécois/Canada""Français".
Mon Aug 29, 2011 3:41 pm
Hi, ...
Respond =
Please, ... remove "Canadien Français" from the list of languages. But now it have the name "Français Québécois/Canada".
It mean = keep "Français" and now "Français Québécois/Canada", from the list of languages.
Also just include the translation file "LanguageFR.xml".
Now "Français" from the list of languages link to the translation file "LanguageFR.xml".
Now "Français Québécois/Canada" from the list of languages link to the translation file "LanguageFR.xml".
SSTSylvain
Mon Aug 29, 2011 3:45 pm
OK, but you want them to load the same file ?
If I understand it correctly
Please = dont use anymore the translation file = LanguageFR_CAN.xml
You were asking us to remove the LanguageFR_CAN.xml file and just use LanguageFR.xml for both Canadien Français and Français ? Or do you want us still to use both files ?
Thanks :thumbsup
SSTSylvain
Mon Aug 29, 2011 3:52 pm
Hi, ...
Respond =
Postby rusticdog » Sun Aug 28, 2011 11:45 pm
Also just include the translation file "LanguageFR.xml", and remove completly the file "LanguageFR_CAN.xml".
SSTSylvain
Mon Aug 29, 2011 3:54 pm
Fantastic :thumbsup
Sorry for the confusion
SSTSylvain
Mon Aug 29, 2011 4:03 pm
Hi, ...
Please, redirect those forum messages, from = http://forum.firetrust.com/viewtopic.ph ... =15#p57142, to this message that you read righ now, to an other section.
Because i whant to only have, in that forum section translation only translation, and not discussion about if i keep translation "French" and "French Canada".
SSTSylvain
Mon Aug 29, 2011 4:10 pm
sst wrote:Hi, ...
Done :thumbsup
SSTSylvain
Re: Questions : "Français Québécois/Canada""Français".
Mon Aug 29, 2011 4:11 pm
Hi, ...
Done :thumbsup
Thanks, ... :thumbsup
SSTSylvain
Return to “Aide française”
