"The Latest Microsoft .NET Framework"
Re: "The Latest Microsoft .NET Framework"
Sun Mar 12, 2017 4:18 am
KnutR wrote:Version 4.6.2 is already installed.
If you already have the installer, perform a reinstall — that causes a corrupt installation to get repaired.
If you don't have the redistributable, download and run the following .NET Framework Repair Tool:—
ps:—
MWP 7 (ßeta) | Windows 10 LTSC (20H2) | The Bat! Professional (ßeta) | Windows 10 Firewall Control (ßeta) | ESET Endpoint Antivirus (ßeta) | nVIDIA GeForce (GTX 1060) | Internet Connection Speed (4G USB tethering — VoLTE) | .NET Framework (4.8)
KnutR
Mon Mar 13, 2017 10:09 pm
4.6.2 is already installed, and Windows will not reinstall it. The Repair Tool made a couple of changes, but the problem was not solved.
Mon Mar 13, 2017 11:23 pm
Did you even read my previous post? :facepalm
Fri Apr 07, 2017 9:05 pm
Microsoft Releases .NET Framework 4.7 (Included in Windows 10 Creators Update)
Microsoft today announced .NET Framework 4.7, the new version that’s available as part of the Windows 10 Creators Update already shipping to users as a manual download.
While at this point version 4.7 is exclusively available to Creators Update users, Microsoft says that it’s already working to release it for users of other Windows versions as well, and download links should be unveiled “soon,” the company claims.
Wed May 03, 2017 7:07 pm
Microsoft .NET Framework 4.7 is just out. :thumbsup
Download:—
Digerati
Microsoft MVP
Thu May 04, 2017 3:27 am
I note there is no reason to download new .NET Framework versions just because a new version is out there. I NEVER do as unneeded versions just waste disk space. Unlike updated versions of most programs, new versions of .NET Framework don't replace the old ones. For this reason, it is not uncommon to have and need several versions.
If you download a program that needs a specific .NET Framework version not already installed on your computer, you will be prompted to download it.
Image Bill (AFE7Ret)
Freedom is NOT Free!
Thu May 04, 2017 5:54 am
Microsoft .NET Framework 4.7 — Changelog
Digerati
Microsoft MVP
Thu May 04, 2017 6:07 am
If you need it, your program requiring it will prompt for it, or Windows Update will recommend you install it.
Thu May 04, 2017 6:14 am
Digerati wrote:It is likely if you have a program that needs that version, you would have already been prompted to install it.
Digerati wrote:If you download a program that needs a specific .NET Framework version not already installed on your computer, you will be prompted to download it.
Digerati wrote:If you need it, your program requiring it will prompt for it, or Windows Update will recommend you install it.
I believe you already mentioned that . . . . . . a number of times, on this very topic. :scratch
Digerati
Microsoft MVP
Thu May 04, 2017 6:41 am
And you already included a link that shows what's new. So I was just following your redundant lead.
Thu May 04, 2017 6:48 am
What seems to be redundant with the "What's New in the .NET Framework" link?
In case you have a better link, please do feel welcome to keep this topic updated.
Wed Oct 18, 2017 10:49 am
Microsoft .NET Framework 4.7.1 is just out. :thumbsup
Download:—
Thu Jan 11, 2018 4:39 am
Microsoft .NET Framework 4.7.1 (Update only) is just out. :thumbsup
Download:—
Tue May 01, 2018 7:20 am
Microsoft .NET Framework 4.7.2 is just out. :thumbsup
Downloads:—
What's new in the .NET Framework 4.7.2
