MailWasher - Pro to ES
Address problems with the installation and initial configuration
BoxSoft
Sat Mar 17, 2012 11:26 pm
I'm a longtime user of MailWasher Pro, and I'm planning to implement ES. I've created a complex series of filters that I would like to apply to MWES. Is this possible?
Mike Hanson
Re: MailWasher - Pro to ES
Wed Apr 18, 2012 6:42 am
Hi Mike
Mostly yes, as they use the same regular expression engine (if you're using the MailWasher Pro 20XX version), but there are not too many differences if you've been using the old MailWasher Pro 6.XX version.
Another thing is there's no 'OR' operator in MWES, and you have to use a newline for the 'AND' operator, and that's only in an unreleased version (although we'll release it quite soon). Are you using Windows or Linux and I'll send you the build.
We do plan on adding the same functionality to MWES as MW Pro has and have done the screens for it, but just haven't got around to implementing it yet. Then we'd be able to swap between products filters easily.
Regards
Nick
Return to “Installation”
