Mail washer 6.5.4 install problems on Win7
berniebee
Sat Aug 25, 2012 7:26 pm
Hi
'Have been using mail washer for quite a while now on a XP machine and upgraded to Win 7.
Want to keep with 6.5.4 as I am registered with this however having problems with install.
I am getting an error message (well 6 of them) that various dll files are missing and to re-install which I have done.
The dll files are
Mozglue
nspr4
pic4
mozqlitb
nssut3
Would love some help please.
thanks
Bernard
Re: Mail washer 6.5.4 install problems on Win7
Sat Aug 25, 2012 10:31 pm
No such issues here, ever - have been doing frequent installs/uninstalls with any problem.
You could try uninstalling your copy of Microsoft .NET Framework and then installing the latest version from the following link:-
http://forum.firetrust.com/viewtopic.ph ... 142#p72212
berniebee
Sun Aug 26, 2012 2:52 am
Hi
There have been issues around this in the past.
I did a search on the board and found the same issue with no solution.
Tue Aug 28, 2012 4:09 am
berniebee wrote:Hi
I'm all awake for some links. ;)
Did you try the suggestion I posted :?:
ataraxy
Tue Aug 28, 2012 5:42 am
TrustFire wrote:Did you try the suggestion I posted :?:
Does v6.5.4 use .NET? I thought that that requirement was only introduced in the new version.
Windows 10
Tue Aug 28, 2012 6:03 am
Drat!!! :P
Got the V6 got mixed up again with the 20xx - perhaps it's time (for me) to unsubscribe completely from the defunct and outdated V6. :)
Tue Aug 28, 2012 6:13 am
berniebee wrote:I am getting an error message (well 6 of them) that various dll files are missing and to re-install which I have done.
The dll files are
Mozglue
nspr4
pic4
mozqlitb
nssut3
Those are Mozilla issues - you'll see them in the Mozilla installation directory (Thunderbird or Firefox.)
[eric]
Fri Feb 01, 2013 4:52 pm
Copy the DLLs to the MailWasher directory.
Fri Feb 01, 2013 5:21 pm
[eric] wrote:Copy the DLLs to the MailWasher directory.
Nope, they don't belong there. :shock: :no
LordElpus
Fri Aug 16, 2013 1:57 am
I'm getting the same issues. Was there ever a solution to the problem. :(
W7/6.5.4/Thunderbird.
