How do I register?
RJ Burke
How do I register?
Fri Sep 28, 2012 8:10 am
The Help pages say "Click Register on the main button bar", but there is no "Register" on the main button bar. I'm looking where to enter my registration key (this is for Mailwasher Pro, not "Enterprise Server")
Re: How do I register?
Fri Sep 28, 2012 8:16 am
You may already be registered. I assume you're using MailWasher Pro 2012? If so, go to Help>>Registration, and that will show if you are registered. If not, then you can enter your key in there.
Nick
Return to “Post Installation”
