Starting Mailwasher 2012.1.21.0 takes > 30 Secs
jahnr
Thu Nov 22, 2012 2:33 pm
Hallo folkes,
my Laptop (XP SP3) - no workload - needs more than 30 seconds to startup.
Can this process be accelerated? If YES -> How to do?
thanks in advance / Danke
Robert
Mailwasher Pro [v7.1.0] ― Mailwasher Mobile [v1.2]
Re: Starting Mailwasher 2012.1.21.0 takes > 30 Secs
Fri Nov 23, 2012 8:31 am
Are you starting MWP when Windows starts?
Fri Nov 23, 2012 9:03 am
jahnr wrote:Hallo folkes,
When I was using an average powered laptop, I used to see this issue. Slower startups in MWP are caused mostly by the contents of cache in your Crypto folder. I now purge my cache periodically (as I do not employ learning) and have been enjoying a swifter startup and shutdown, as well. ;)
MWP 7 (ßeta) | Windows 10 Pro (2004) | The Bat! Professional (ßeta) | Windows 10 Firewall Control (ßeta) | ESET Endpoint Antivirus (ßeta) | nVIDIA GeForce (GTX 1060) | Internet Connection Speed (4G USB tethering — VoLTE) | .NET Framework (4.8)
jahnr
Fri Nov 23, 2012 9:15 pm
@Sidewinder - I start MWP separately from Windows start to avoid a peak workload when booting
@Trustfire - a funny nickname :-)) - HOW to purge the cache? Plse give me advise
Robert
Fri Nov 23, 2012 9:53 pm
jahnr wrote:@Trustfire - a funny nickname :-))
:devil
jahnr wrote:HOW to purge the cache? Plse give me advise
(Click) Help >>----> (in the Explorer window that opens up, click) User Files... >>----> cache >>----> crypto >>----> (a lot of cached files get accumulated within this directory over a period of time. Deleting these files improves the startup speed, but also causes all Spam learning to be reset.)
jahnr
Sat Nov 24, 2012 2:41 am
@Trustfire - Thx it helped savin 5 Secs.
Robert
Sat Nov 24, 2012 3:01 am
You might also want to take a look at your security software it may be causing part of the problem. Also if you have the MWP setting to do the Check Mail when it starts try removing that option and then when MWP finishes loading either wait for the next timed check or manually trigger a Check Mail.
jschumann
Sat Nov 24, 2012 1:28 pm
Where do I find 1.21?
Sat Nov 24, 2012 6:01 pm
jschumann wrote:Where do I find 1.21?
1.21 is a beta release available only to beta-tesers. ;)
