How are Filters triggered ?
geogordon
Fri Dec 28, 2012 1:30 pm
I had an INITIALLY sucessful first experience with a REGEX spam filter. Using Excel, I created a large REGEX filter, and HAPPILY, if performed perfectly on the first try, clearly marking a nukber of emails, as I specified in the filter design.
Howwver, being my first filter, I needed to make a few changes, so I redefined the filter. SURPRISE -- I found that my filter maked NOTHING. I then entered a really simple REGEX filter (just one item), and that filter also marked NOTHING.
I closed Mailwasher Pro, then restarted it, but AGAIN -- the REGEX filter marked nothing.
MY QUESTIONS --
1. Under what conditions doesdoes Mailwasher trigger its filters?
2. Is ther any way for me to manualy trigger a REGEX filter? If YES, that can I trigger all of them at once, or one at a time.
FINALLY -- The REGEX filter is a fabulous Mailwasher tool. As soon as I master how to use them Mailwasher willbe more valuable than ever. REGEX is my solution to junk and spam mail.
Re: How are Filters triggered ?
Fri Dec 28, 2012 2:17 pm
Two easy ways to trigger your filters, clear the grid and do a mail check or open the filter and then save it, when you return to the mail grid screen the filters will be run. No way to just run one filter except manually disabling the others.
Regex is incredibly picky so you may have an unintentional blank space or possibly a typo causing the problem.
Thu Jan 10, 2013 9:40 pm
johny3329 wrote:Hi, I'm using v6.5.4 MW in my Win XP 32bit pc. I am awaiting delivery of a Win7 64bit pc and would appreciate it if you can tell me if I can run my MW in 64 bit.
Yes - check out my signature!!! ;)
johny3329 wrote:Thanks. I haven't checked yet, but does the new MW have a 64 bit version? :)
Unfortunately, no. :(
Edit:
  • Next time, please start a new thread when your subject is different from the one being discussed.
