Bounce Button
- lipshutz
Bounce Button
In the old Mailwasher there was the ability to check delete, blaclist and BOUNCE. In the current version you can only bounce manually as there is no column set aside fot this. Can this be included?
- TrustFire
Re: Bounce Button
No, it cannot and . . . . . . . . . . . should not be included.lipshutz wrote:Can this be included?
MailWasher Pro 7 (ßeta) | Windows 10 LTSC (22H2) | The Bat! Professional (ßeta) | Windows 10 Firewall Control (ßeta) | ESET Endpoint Antivirus (ßeta) | nVIDIA GeForce (GTX 1060) | WebView2 Runtime (109.0.1518.70) | .NET Framework (4.8.1)
