Outlook
Parbuster
Outlook
Mon Jan 28, 2013 12:56 am
On some websites if I have to send an email through that site it alays seems to have Outlook as the client,when I try to send the message it just goes in Drafts and does not send through Outlook.Is this because I use WLM as my default client and what do I do to correct this?????
Pierre
Re: Outlook
Mon Jan 28, 2013 6:11 pm
No, it would not be MailWasher that is causing your problem. It must be the settings in Outlook - which version of Outlook do you have installed? I will possibly be able to help you. BTW You posted in the wrong forum. For MailWasher 2011/2012 the link is http://forum.firetrust.com/viewforum.php?f=50 and for MailWasher 5 and 6 it is http://forum.firetrust.com/viewforum.php?f=13
