Wish: sorting option
racker
Thu Jan 31, 2013 7:32 pm
Now that I'm able to sync my Gmail (using POP settings), i've encountered a new problem: As I use Gmail as an archive, it holds ten years of mail. MWM does not have a sorting option and displays eldest mail first. Result: I need to scroll down, through thousands of mails to reach the latest, as soon as I include Gmail(POP) in MWM... :facepalm
I realize that this isn't excactly "normal use" with POPmail, (then again: what's Normal"?? :ninja :devil) but I fear that more people will encounter this problem as soon as IMAP is supported somewhere in the near future.
So: IMHO, a sorting-by-date option in MWM would "come in very nicely", surely before implementing IMAP.. :bow
Beta tester.. oh well! ;)..
MWP FAQ
Re: Wish: sorting option
Thu Jan 31, 2013 8:28 pm
It should display the most recent mail. Have you thought about using the 'recent' command for gmail? http://support.google.com/mail/bin/answ ... swer=47948
racker
Thu Jan 31, 2013 9:09 pm
nick.bolton wrote:It should display the most recent mail. Have you thought about using the 'recent' command for gmail? http://support.google.com/mail/bin/answ ... swer=47948
Ahhh thx for your fast reply.. that works. I wasn't aware of that possibility! :bow
Still: I think an option to influence the way in which MWM sorts/displays could come in handy (albeit less urgent than I thought it was).. :)
MWP FAQ
Thu Jan 31, 2013 9:12 pm
Yes, sure. There's plenty of things we'll want to add, just keen to get a finished basic version out first :)
