A note to people who use CCleaner
- TrustFire
Re: A note to people who use CCleaner
CCleaner 5.42.6495 is just out.
- TrustFire
CCleaner 5.42.6499 is just out.
- TrustFire
CCleaner 5.43.6520 is just out.
- TrustFire
CCleaner 5.43.6522 is just out.
- TrustFire
CCleaner 5.44.6575 is just out.
- TrustFire
CCleaner 5.45.6611 is just out.
- TrustFire
CCleaner 5.46.6652 is just out.
- parishef
Hello I have it unchecked in ccleaner and have deleted flash player BUT when checking for mail washer pro updates it says there are none BUT yet when you check the website there is an update rather strange that this does this so any ideas why it would do this?
schnief wrote:[UPDATE] : This problem is now fixed in the latest version of CCleaner.
Hi from Berlin,
I just had a rather negative experience with one of my favorite tools: CCleaner.
I always use the zip version, and today a new version came out. (http://www.piriform.com/ccleaner/builds). As always, I set it up over my old version and ran the cleaning function.
All of a sudden, I noticed it had wiped out many MBs of data from MWP, specifically from the folder that holds the contents of the Recycle Bin![]()
Fortunately, Piriform, the company that makes CCleaner, also makes an undelete program called Recuva, with which I was able to fix pretty much everything.
My tip: If or when you install a new version of CCleaner, look under the "Applications" tab in the "Cleaner" section, and make sure MailWasherPro is unchecked.![]()
Hope this helps.
Best regards,
JoeG
- TrustFire
CCleaner 5.47.6701 is just out.
- TrustFire
This version has now been recalled.TrustFire wrote:CCleaner 5.47.6701 is just out.
- TrustFire
CCleaner 5.47.6716 is just out.
- TrustFire
CCleaner 5.48.6834 is just out.
- TrustFire
CCleaner 5.49.0.6856 is just out.
- TrustFire
CCleaner 5.50.0.6911 is just out.
