A note to people who use CCleaner
Warwick
Re: A note to people who use CCleaner
Sat Mar 30, 2013 3:55 pm
I noticed that Mailwasher was included in CCleaner (Pro) and wondered if it would empty the MW recycle bin. If I remember correctly, it didn't, but that might have been because I had System / Empty Recycle Bin unticked in CCleaner.
Sat Mar 30, 2013 10:06 pm
Warwick wrote:I noticed that Mailwasher was included in CCleaner (Pro) and wondered if it would empty the MW recycle bin.
The MWP Recycle Bin is not to be confused with the Recycle Bin entry on CCleaner.
ATM, the MWP entry at CCleaner bears a flawed rule that can result in loss of the MWP Learning data and Friend's List. It is highly recommended to leave that entry un-checked (disabled.)
Warwick wrote:If I remember correctly, it didn't, but that might have been because I had System / Empty Recycle Bin unticked in CCleaner.
When the Recycle Bin entry on CCleaner is left checked (enabled,) CCleaner will clean the Recycle Bin that comes with one's OS - this entry is not related to the MWP Recycle Bin.
MWP 7 (ßeta) | Windows 10 LTSC (21H1) | The Bat! Professional (ßeta) | Windows 10 Firewall Control (ßeta) | ESET Endpoint Antivirus (ßeta) | nVIDIA GeForce (GTX 1060) | Internet Connection Speed (4G USB tethering — VoLTE) | .NET Framework (4.8)
KJS
Prudent Pukeko
Thu Apr 11, 2013 11:44 am
I use CCleaner. It doesn't list Mailwasher. It lists McAfee which isn't installed on my system....
Thu Apr 11, 2013 11:53 am
KJS wrote:I use CCleaner. It doesn't list Mailwasher. It lists McAfee which isn't installed on my system....
Just be careful of the update it will wipe your BL, FL and Bayesian learning data.
Thu Apr 11, 2013 4:40 pm
Is your CCleaner the latest 4.00.4064 :?:
KJS wrote:It lists McAfee which isn't installed on my system....
You may try deleting the following 2 registry entries:-
  • [HKLM\SOFTWARE\McAfee\AVEngine]
  • [HKCU\Software\SiteAdvisor]
KJS
Prudent Pukeko
Fri Apr 12, 2013 2:44 am
Oh, no. It's 3.26.1. I'll check that out, thanks.
Fri Apr 12, 2013 4:03 am
You can also subscribe to the CCleaner topic which is listed along with other useful software at the internal beta channel; to be amongst the first ones to receive notifications of new releases. ;)
Fri Apr 12, 2013 2:06 pm
For what it's worth, the "CCleaner Team" (whoever that is) are idiots.
Here is the reply I got from CCleaner....
I've forwarded this information over to our CCleaner team, who believes that this problem does not exist when using the latest version of MailWasher. I understand that you are affiliated with Firetrust, the makers of MailWasher, so I am not certain that this will help.
If you're already using the latest version of MailWasher, please let us know. If not, can you please update to the latest version of the software and check to see if the problem still exists?
:crazy
Fri Apr 12, 2013 5:06 pm
Bloody Muppets!!! :facepalm
Fri Apr 12, 2013 5:10 pm
TrustFire wrote:Bloody Muppets!!! :facepalm
Not encouraging, but we'll get there eventually.
schnief
Guardian Gecko
Location: How can you be in two places at once when you're not anywhere at all?
Fri Apr 12, 2013 7:14 pm
rusticdog wrote:For what it's worth, the "CCleaner Team" (whoever that is) are idiots.
I don't know if this'll help, but I've sent Piriform the link to a little video I made.
http://edu-net.net/media/ccleaner/
By the way, I'm aware I didn't completely or accurately explain what it actually does to MWP, but I figured it would be OK.
MWP on Win7 Pro SP-1 x64 on two Lenovo S20s, two Thinkpads, and two HP Elitebooks. MWP also on three Win10 Pro x64 machines (two Intel NUCs and an Asus Zenbook). All have Norton Security, Malwarebytes Premium, and Surfshark VPN.
Fri Apr 12, 2013 7:20 pm
Coolio :thumbsup
In my earlier email to them I did specifically detail what files are safe to remove at any time, being .log and the logs subfolder. They just don't believe me quite yet.
schnief
Guardian Gecko
Fri Apr 12, 2013 7:28 pm
rusticdog wrote:Coolio :thumbsup
If you happen to see Peter Jackson, please tell him I'm gettin' a new camera and am gettin' ready for my newest film epic: "The Lord of the Rings Meets the Hobbit While Using Mail WasherPro" - so he'd better watch out!
Mon Apr 15, 2013 11:56 pm
Warwick wrote:I noticed that Mailwasher was included in CCleaner (Pro) and wondered if it would empty the MW recycle bin. If I remember correctly, it didn't, but that might have been because I had System / Empty Recycle Bin unticked in CCleaner.
Wed Apr 17, 2013 12:54 pm
Quick update.
I've contacted our CCleaner team again who has confirmed this as an issue and said that they will have this fixed in the next version of our software, which will be released around April 25th.
