Is there a new release?
cfheinz
Guardian Gecko
Fri Mar 29, 2013 11:01 pm
I got an update message, but I've not received the email notification.
Carl Heinz
cfheinz
Guardian Gecko
Re: Is there a new release?
Fri Mar 29, 2013 11:12 pm
I've just received an MWP beta update message, but haven't received one for MWM.
Carl Heinz
anniebrion
Sat Mar 30, 2013 12:01 am
cfheinz wrote:I've just received an MWP beta update message, but haven't received one for MWM.
The two applications can have independent updates if changes in one don't affect the other.
stmiranda
Sat Mar 30, 2013 3:09 am
I started receiving a message to update as well but don't find one.
Sat Mar 30, 2013 3:29 am
stmiranda wrote:I started receiving a message to update as well but don't find one.
Message on your device or an email?
cfheinz
Guardian Gecko
Sat Mar 30, 2013 3:50 am
I got the "Please Update" message when trying to use MWM on my iPad. I haven't yet received an update MWM email message.
Carl Heinz
Sat Mar 30, 2013 4:24 am
Check here:
http://forum.firetrust.com/viewtopic.ph ... 635#p78646
If you are using IOS it is now in the ITunes App Store.
stmiranda
Sat Mar 30, 2013 4:25 am
Sidewinder wrote:Message on your device or an email?
Message is on my device. When I open the app, I get in red at the top the following:
"Please Update To The Latest Version Of MailWasher Mobile"
It started late last night. After the message, all I get is a white screen. Android application manager shows version 1.0.
Edit: I cleared the cache and data and force stopped the app. No change. Online Google Play shows the app installed as well, fwiw.
cfheinz
Guardian Gecko
Sat Mar 30, 2013 5:55 am
Thanks. I had to delete the old version before the one from the App Store would work.
Carl Heinz
cfheinz
Guardian Gecko
Sat Mar 30, 2013 6:04 am
Now I am getting alternatively cannot connect using email and the update version messages.
Carl Heinz
Sat Mar 30, 2013 7:49 am
cfheinz wrote:Now I am getting alternatively cannot connect using email and the update version messages.
See Nick's post here:
http://forum.firetrust.com/viewtopic.ph ... 691#p78866
cfheinz
Guardian Gecko
Sat Mar 30, 2013 8:16 am
Thanks. When I checked a couple of minutes ago, the problem persists.
Carl Heinz
Sat Mar 30, 2013 8:51 am
Ok, should be fixed now. We had the wrong version file on the new servers :facepalm
stmiranda
Sat Mar 30, 2013 5:21 pm
cfheinz
Guardian Gecko
Sun Mar 31, 2013 10:58 pm
Working ok.
Carl Heinz
