Session Encountered Problems
wombat
Thu Sep 26, 2013 11:17 am
Hi Guys,
I am using MWP 6.5.4 with Win 8 and I get this error when I open MWP on startup or when I open manually from my taskbar, what have I done wrong? (see attached file)
Is it a Win8 problem?
Your expert help would be appreciated.
Regards Ron
MW Pro 6.5.4.jpg (82.67 KiB) Viewed 4110 times
ataraxy
Re: Session Encountered Problems
Thu Sep 26, 2013 2:39 pm
This looks like a problem with the set up for this email account. Has this account ever worked?
Windows 10
wombat
Thu Sep 26, 2013 4:15 pm
Hi ataraxy,
yes the account has worked in XP, Vista but will not work in Win 8.
I copyed all setting from this laptop to my new Win 8 one, when I say copyed I mean I had MWP open on vista and put the same settings into Win 8
Regards Ron
Thu Sep 26, 2013 5:00 pm
wombat wrote:Is it a Win8 problem?
wombat wrote:yes the account has worked in XP, Vista but will not work in Win 8.
Just tried using the 6.5.4 (again) on Windows 8 - it works fine for me without any errors (has always been so.) :)
wombat
Thu Sep 26, 2013 5:05 pm
still no luck here, still using v6 because I am a pensioner and cannot afford the lastest version
Thu Sep 26, 2013 5:15 pm
Which e-mail service are you having the problem with - for example, Yahoo! Gmail, etc., etc?
wombat
Thu Sep 26, 2013 5:20 pm
Thanks TF, Hotmail
Thu Sep 26, 2013 5:27 pm
Unfortunately, can't post any screenshots, for you - since I personally do not use Hotmail. :(
I'd suggest double-checking your e-mail settings (especially the POP3 protocol) against the recommended ones at the following link:--
http://www.firetrust.com/en/hotmail_pop3 :thumbsup
wombat
Thu Sep 26, 2013 6:15 pm
thanks TF, just printed those instructions will have a look at it now.
wombat
Fri Sep 27, 2013 7:11 pm
Hi TF,
sorry for not getting back sooner, I will be trying your suggestions tomorrow, will let you know how I go.
Fri Sep 27, 2013 7:19 pm
Sure wombat, take your own time - no worries. :)
wombat
Fri Oct 04, 2013 8:18 pm
again, sorry for taking so long, I redid all my settings as per your instructions, and all is working ok now, thank you for your help
Fri Oct 04, 2013 8:27 pm
Awesome! :thumbsup
Glad you got that resolved — thanks for writing back. :)
