MW Mobile version 2.0 beta - Windows Phone 8
anniebrion
Sat Apr 12, 2014 12:06 am
I added my outlook account that went fine, so I tried to add Gmail, the email from this account show in ALL but there is no entry for Gmail in the account list until you close down the browser and restart.
When scrolling you keep opening emails :thumbsdown
Works on my Windows 8.1 update Tablet as well as my phone :thumbsup
Seems to be running rather slow on my tablet :thumbsdown
Mailwasher Pro βeta [v 7.12.17]
anniebrion
Re: MW Mobile version 2.0 beta - WP8
Sat Apr 12, 2014 2:33 am
Not sure it's working, I have 1 email in MWP Desktop but when I refresh MWP mobile, using the same mailbox account, is says "No new emails".
Sat Apr 12, 2014 2:42 am
anniebrion wrote:Not sure it's working, I have 1 email in MWP Desktop but when I refresh MWP mobile, using the same mailbox account, is says "No new emails".
Double Check your Account Port/SSL's
It looks like I'm seeing the same problem with IOS/Chrome
anniebrion
Sat Apr 12, 2014 2:45 am
Looks fine:
Outlook
pop3.live.com
995
SSL
Sat Apr 12, 2014 2:48 am
It looks like the FT server is not refreshing.
anniebrion
Sat Apr 12, 2014 3:07 am
Sidewinder wrote:It looks like the FT server is not refreshing.
I agree as another email has arrived but mwp mobile is still empty.
Sat Apr 12, 2014 4:41 am
I had one sync on Initial Account set up and another when I changed my port/SSL settings but nothing since.
Sat Apr 12, 2014 7:00 am
Correct, it's not auto-checking for new mail yet, but if you pull down to refresh, wait a bit...ok no it's not - and that's not very useful to anyone :? Fix will be on it's way.
Yes, I noticed this too when using the mouse instead of touch screen - they're treated differently, but something much have broken as it was working.
This is using IE 11 on a Microsoft Surface tablet?
anniebrion
Sat Apr 12, 2014 7:07 am
Manual refresh is not working either.
Scrolling issue is with touch and not mouse
It's slow in Firefox, IE11 on my XPS18 Tablet is much better.
Sat Apr 12, 2014 7:15 am
Thanks, confirmed manual refresh is not working. Odd it's slow in Firefox but we'll check it out, although desktop browsers are not really the focus it should still be fast there.
anniebrion
Sat Apr 12, 2014 7:21 am
Please, don't waste time on Firefox, it is more important to get the app shell up and running, it's perfectly acceptable to use IE11 on windows tablets.
anniebrion
Re: MW Mobile version 2.0 beta - Windows Phone 8
Mon Apr 14, 2014 9:03 pm
I have 3 emails in my outlook account this morning and did not perform a manual update, I also added another pop account that loaded the correct number of emails.
Are we getting IMAP support? As I use this as my main connection method in MWP Desktop as I need to check some sub-folders as well as the Inbox.
Mon Apr 14, 2014 9:29 pm
Yes, we got the auto-check working today so you'll see new emails :)
We will add IMAP, we'll get all the other stuff on the list done first though. It's pretty important as services like iCloud are IMAP only.
anniebrion
Mon Apr 14, 2014 10:01 pm
Thanks :thumbsup
FYI, manual update (pull down) still is not working here.
anniebrion
Mon Apr 14, 2014 10:30 pm
Manual update just worked for the first time :thumbsup
But it does not work every time :thumbsdown
