Filters in Beta 4
Chariott
Filters in Beta 4
Mon Jun 30, 2014 2:15 am
You note in the what's coming next section of the 2.0.0 beta 4 announcement that the next version will have —
Custom filters - limited to text filters probably - not regular expressions. - done but not yet added in.
I'm not sure I understand that. At present I have hundreds of filters in MW Pro, but all are based on a filter type (Good, Spam, Neutral) and rule using the From - Contains - Plain Text options with the email address (or part of it) typed in the entry field. Would this type of filter be what you mean by "limited to text filters"? Will we be able to sync MWM with filters in MW Pro?
Any hope for the ability to bounce e-mails from MWM?
Tony
Re: Filters in Beta 4
Tue Jul 01, 2014 6:52 am
Yes, those plain text filters are the type which will be supported. If you have hundreds of filters setup, then I imagine you could get some economies going by combining those filters in to a few less.
You will be able to sync those from MW Pro, although we might limit those so there's not hundreds. We still need to work this out.
Don't think we'll have bouncing, for one it doesn't really work anymore and annoys ISP's, and we don't have the ability to send emails which is what bouncing needs.
