Mailwasher Pro 6.1 version
barrycantiow
Wed Jul 02, 2014 9:07 pm
Hello, I am changing my email from pop3 to GMAIL
I am having trouble setting this up with Mailwasher Pro 6.1
The add email options are for POP3, Hotmail, IMAP & ADL
So does this mean I cannot add my GMAIL?
Any help please?
Barry
barrycantiow
Re: Mailwasher Pro 6.1 version
Wed Jul 02, 2014 9:13 pm
I am running Windows 7 and have been using Mailwasher for a long time with very good results.
Wed Jul 02, 2014 9:17 pm
Hi Barry
GMail are an email provider, whereas POP3 and IMAP are the systems used to access the email account. For GMail the settings to use POP3 to access the account are :
POP server address : pop.gmail.com
Username : your full gmail email address
You also need to click the Advanced Account Options and be sure the Server Port Number is set to 995 and the Secure Connection Type is set to SSL
Chris
barrycantiow
Wed Jul 02, 2014 9:36 pm
Many thanks for your help Chris, I will try it now. :D
barrycantiow
Wed Jul 02, 2014 9:49 pm
OK Chris, I can download them OK through Mailwasher and then into Outlook, many thanks for your help. :)
Wed Jul 02, 2014 9:52 pm
Great!
