In recent weeks a new box has appeared at the top of these forums telling me the time and date - it is supplied by timeanddate.com. Apart from the fact that I am hardly interested in what the time is in New Zealand (and it doesn't seem to honour UK time in my control panel settings) I find its black box a bit off-putting. Together with that it insists in dropping a 'Free Time and Date' cookie in my browser (which is what led me to try and find out what was doing that).
Is there any way to remove this box.....
Dave
timeanddate.com
- TrustFire
Re: timeanddate.com
Cookies are not required at the firetrust.com - you can safely disable your cookies for this site.davews wrote:Together with that it insists in dropping a 'Free Time and Date' cookie in my browser (which is what led me to try and find out what was doing that).
You can try the Adblock Plus add-on, for Firefox - Element Hiding Helper for Adblock Plus is great companion, too.davews wrote:Is there any way to remove this box.....
Dave
- davews
Re: timeanddate.com
Well cookies ARE required at firetrust.com - how on earth otherwise are you able to login. But I was talking about the timeanddate.com inserted time box - that is what gives me cookies, from free.timeanddate.com. It should not do that anyway as those are third party cookies which I have blocked in my browser but they seem to get through anyway.
I have solved the problem by switching to the 'subsilver' skin which does not use the timeanddate box - and displays the correct UK time by different means.
- TrustFire
Re: timeanddate.com
Can't say for sure, why they might be required on your system — on all my systems, I am able to login without an issue, with all cookies completely disabled for forum.firetrust.com.davews wrote:Well cookies ARE required at firetrust.com - how on earth otherwise are you able to login.
No third party cookies are permitted on my systems — FWIW, I am running the CookieSafe add-on with Firefox.davews wrote:But I was talking about the timeanddate.com inserted time box - that is what gives me cookies, from free.timeanddate.com. It should not do that anyway as those are third party cookies which I have blocked in my browser but they seem to get through anyway.
Personally, I detest stuff and info., irrelevant to my browsing needs and strip them away from sight — this is how the Firetrust pages appear on my browser:—davews wrote:I have solved the problem by switching to the 'subsilver' skin which does not use the timeanddate box - and displays the correct UK time by different means.
- Firetrust.png (631.03 KiB) Viewed 31421 times
- TrustFire
Re: timeanddate.com
This problem is now resolved, at root — no more timeanddate.com with the new forum upgrade (at least, so far.)
- TrustFire
Re: timeanddate.com
Shortly after having made this post, have switched my choice of ad. blocking tools since; to a much more aggressive and potent combination.TrustFire wrote:You can try the Adblock Plus add-on, for Firefox - Element Hiding Helper for Adblock Plus is great companion, too.
